Results 1 to 19 of 19
Thread: Test kit
    Jun 2016
    Michigan
    50
    Test kit
    I want to get a test kit but I do not which one to invest in. On the site the kaylor 2006 and tf 100 have been recommended, but neighbors are telling me that the Lamotte colorq pro 7 test kit 2056 is alot better. Any advice on the value and quality of a couple different quality test kits?
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: Test kit
    Yes, stick with either the taylor K-2006 or the TF-100. If you read in the archives here you'll see folks aren't terribly happy with the ColorQ.
    The most important aspect of the testing kits we trust is that they come with drop tests, in particular the FAS-DPD test for chlorine and CC up to 50ppm. If you ever have a problem with algae you need a tester that goes higher than the standard 5ppm or 10ppm at the most.
    Homework: Pool School - Test Kits Compared
    Jun 2016
    Michigan
    50
    Jun 2014
    15,221
    Re: Test kit
    Pete, I posted on your other thread to look for this one: Amazon.com : Taylor Service Complete Pool Water Test Kit K-2006C : Swimming Pool Liquid Test Kits : Patio, Lawn Garden.
    Before you buy though, I would recommend comparing all the kits and how much you get. The TF-100 is a great value.
    Stump's Avatar
    Jul 2013
    Oklahoma
    145
    Re: Test kit
    What Texas Splash said and add on XL option.........Keep your kit indoors and the chemicals will last a very long time in controlled temperature environment.
    24' Reprieve RD/AG/13K gal Vinyl TFP method
    Waterway Clearwater 175 sqft Cartridge
    Hayward Power-Flo Matrix 1HP Pump 2-Speed
    TF-100 Test Kit SpeedStir Borate Insta Test
    Spreading TFP to All
    Major_in_MS's Avatar
    Jul 2016
    Florence, MS
    94
    Re: Test kit
    Quote Originally Posted by Pete23 View Post
    The C kit comes with more reagents so you can perform more tests before having to order refills.
    The one you linked to is the smaller kit with .75 ounce reagent bottles..
    The C kit has 2 oz reagent bottles. http://smile.amazon.com/dp/B0002IXIJ0
    24,200 gal., IG vinyl, 18' x 36' rectangular, average depth 5'. K-2006C
    Jandy SFTM22 sand filter, 1.65 HP PureLine VS Pump, Doheny's Discovery Robot.
    One skimmer, one main drain, two eyeball jets, and one return from the booster pump.
    One wife of 28 years (schoolteacher, first grade), four kids (ages 16,18,19, and 21).
    I work night shift (Pediatric RN) so most of my posts will be during the night.
    Jun 2016
    Michigan
    50
    Re: Test kit
    How does the tf100 compare to the tf100 xl?
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Test kit
    Also get the speedstir...a must in my book!
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    38,470
    Re: Test kit
    The XL just adds more of the FAS-DPD chlorine test reagents ... this is a must if your have to SLAM your pool just so you do not run out of it when testing high FC levels.
    JenF75's Avatar
    Jul 2017
    Stouffville, ON, Canada
    49
    Re: Test kit
    I'm going to order the TF100 test kit, but because I'm in Canada, not really close to a border, I want to make sure I'm getting everything I need in one trip. Do the reagents last long? Could I order refills and they would still be good to use next season? Do I need a speedstir? (I've never done my own testing, not even sure what it is). Anything else I should consider buying? Thanks!
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    5,521
    Re: Test kit
    In Canada, you cannot direct ship a TF100 to you. Lowry and associates has a monopoly on selling Taylor reagents.
    The only way to get a TF100 is to ship it to a mail drop in a USA border town, and you go pick it up.
    I would suggest a SpeedStir. It does make my testing much easier.
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa
    Pentair CCP240 Cartridge Filter with Pentair Intelliflo 3050VS Pump and Pentair HTR250 heater. IC40 SWG. EasyTouch 4. TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Marty
    JenF75's Avatar
    Jul 2017
    49
    Re: Test kit
    Yes, I am shipping it to a mail drop box and picking it up. That's why I want to make sure I order everything I need. Will the reagents be good next year if I order refills? I will also order the SpeedStir. Can you suggest anything else I might need? Thanks for your input.
    23,000 gallons, IG vinyl pool with low salt system SWCG and cartridge filters. Installed November 2016. Zodiac MX8 Elite automatic pool cleaner, TF100 test kit.
    May 2014
    Laughlin, NV
    5,521
    Re: Test kit
    Great! Typically the things I order the most are CYA reagent, FAS-DPD, and pH reagent.
    The items in the kit will last 2 years from an expiration standpoint. So I would suggest only getting extra of the above. If you order the TF100 XL it will have the extra FAS-DPD reagents. You would need to order an extra bottle for CYA and the pH.
    Call them at TFTestkits.net. Your situation is a little unique so would be better than ordering over the internet.
    Take care.
    Marty
    38,470
    Re: Test kit
    Note: the reagents officially "expire" in 12 months. That is what Taylor states and what tftestkit.net will warranty ... although many of us have used some much older than that without issue.
    May 2014
    Laughlin, NV
    5,521
    Re: Test kit
    Did not know that! I had heard 2 years -- thank you Jason!!
    Marty
    JenF75's Avatar
    Jul 2017
    49
    Re: Test kit
    Thanks for all your help. I think I'm going to buy a pH meter (just discovered this exists!) as my pH is always creeping up. I usually have to add 3 liters or so of muriatic acid per week, so I think it would be worth it.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Test kit
    I'd pass on the meter and get the speedstir.
    JenF75's Avatar
    Jul 2017
    49
    Re: Test kit
    Finally got my test kit and just playing with it now. Can I use the Speedstir for the chlorine drop test?
    JoyfulNoise's Avatar
    May 2015
    13,247
    Re: Test kit
    Quote Originally Posted by JenF75 View Post
    Yes...the Speedstir can be used for all tests. Unnecessary for pH or CYA but some folks like to use it anyway
    Matt
