Thread: Can't get rid of cloudy pool!
    Jun 2015
    Revere/MA
    2
    Hello everyone!
    On Wednesday I opened my 20,000g inground pool for the season and in the beginning after removing the pool cover, it was green then I added shock and algaecide, then the pool cleared up but is now cloudy. My free chlorine level consistently stays low and I've added a total of 8 gallons of shock since Thursday. I use a test strip and all of the readings are good within normal range except for the free chlorine level. Even after shocking the pool, by the next morning when I test the water the free chlorine level would be low again. The stabilizer level is ideal. I have brushed the walls and floors of the pool and has been running the filter since Wednesday. I have a cartridge filter and clean it every day since Wednesday of opening the pool. I bought the cartridge last summer and there are no rips or anything still in good condition. . I am confused as to why my pool is still cloudy? Am I not adding enough shock? Or am I suppose to be a little more patient as the cloudiness takes time to disappear? Today is Monday already and I'm not sure what to do next hoping to not have to spend an arm and a leg to fix this problem. Please help!!!
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: Can't get rid of cloudy pool!
    Welcome to TFP You have a problem, we've got the answer! Here you go... the basic answer to your problems is BLEACH! And then MORE BLEACH!
    Quick Reads--> ABCs of Pool Water Chemistry and SLAM
    And a proper test kit which you don't have so you actually don't know what any of your numbers are. Pool School - Test Kits Compared
    oh yeah, one last thing... algaecide doesn't kill algae. Its a preventative measure, and one we rarely recommend if you keep your FC at the right level for your CYA.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    Lpham777:
    Welcome to TFP and we are here to help! Although, we need accurate test results. From this point, we can guide you in taking care of a swimming pool the proper way. Continuing to throw in "shock" and/or chemicals that are not needed is not the answer. As mentioned by YippeeSkippy, Bleach is your answer. The amount needed is all based on your CYA level. Everything else can be taken care of later.
    The process could take up to 2 weeks, if not sooner. Although, you will have to test your water at least daily, if not more frequently to make sure that you maintain the chlorine at the recommended SLAM level, again working in partnership with your CYA. This is why we here at TFP are so adamant about owning only one of the recommend test kits. We all know others just do not compare.
    Please add your signature and while waiting for the kit, it is highly recommended you do some reading on the TFP site. Thanks!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jun 2015
    Revere/MA
    2
    Thanks for the reply guys!!! Sorry as I am fairly new to this site and new to owning my first pool. Last year I hired a professional pool guy who did everything to open the pool so this year I wanted to try it on my own. Before I posted my initial post I added some shock to the pool for the night. As of this morning I tested the water again with the strips and everything has changed to ideal/ within normal range included free chlorine and CYA... That would mean I wouldn't have to add anymore bleach right? I have read that you can add "flock" to the pool but that would be the last thing I would like to do.
    My pool is mildly cloudy, it's pretty blue but I just can't see the bottom of the pool. I took some pictures of the tests and how the pool looks this morning to show you guys but I don't know how to add it to my post.
    Jul 2015
    Central Valley CA
    1,107
    The strips are generally not trusted on this site they have too wide a margin of error to be accurate. Even if they did work as intended the term ideal would be under normal circumstances. Since you are cloudy you are not in the ideal range and your FC likely needs to be higher to clear things. As YippeeSkippy mentioned we would need you to have one of the recommended kits to be able to suggest a course of action. We don't want to "pool store you" and just tell you to dump a bunch of chemicals in the water and everything will be great, we want you to understand what is happening in the water and give you educated time test methods to deal with it.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP!
    With an FAS/DPD chlorine test you can measure FC up to 50 ppm +/-0.5 ppm. With that you can perform the Overnight Chlorine Loss Test to determine if there is algae growing in the pool. Then if there is you can kill it using this process, SLAM
    I use the TF-100 and I have been buying mine from TFTestkits.net for many years.
