Thread: Things were going so well...
    FattyLumpkin's Avatar
    May 2016
    Massachusetts
    188
    Hey all. I had my pool very nicely balanced per TFP saltwater guidelines. I just got back from a week vacation, and now my FC will no longer hold. Test results:
    FC 0.5
    CC 0
    CYA 70
    TA 100
    CH 250
    pH 7.6
    Pump is running the same as it was all summer to this point. My swg was at 60% but was losing 1ppm FC net daily, so I kicked it up to maintain 5 FC. That was before a week away. Now I can't hold my FC despite kicking the swg to 100% and bumping the pump run time up to 16 hours (waaaay longer than I was before). I was concerned about too much organic burning thru the FC, but there's no CC either. The cover has been on about 10 straight days at this point. The water is still clear, but I see algae in my future.... Soon. Any insight? I'm puzzled.
    / 24k Gal, 18x36 Freeform IG Vinyl Saltwater / Sta-Rite MPRA6E-205L 1HP Pump / Sta-Rite System:3 Cartridge Filter / IC-40 SWCG / Dolphin Nautilus Cleaner / TF-100 Test Kit w/ SpeedStir / Taylor K-1766 Salt Test /
    Useful Links: Recommended Levels / SLAM / FC/CYA Chart / Test Kits Compared / Edit Your Signature
    38,290
    Re: Things were going so well...
    A SWG will not raise the FC from 0 if anything is in the water ... it is too slow. That is why you should use bleach to raise the FC (and the SWG will eventually maintain it).
    Likely you need to follow the ShockLevelAndMAINTAIN Process
    May 2016
    Massachusetts
    188
    Thanks, just puzzled that it was seeming to maintain ~5 FC prior to my being away, and I returned to 2 yesterday, and 0.5 FC today. I guess I'll go get some bleach. And then possibly SLAM.
    May 2016
    Massachusetts
    188
    With a CYA of 70, it will be a fun SLAM.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    I SLAMed at 70 last summer, it isn't bad. Once you get FC up to 28 your daily burn rate is actually lower because the FC is better protected from the sun. Bright side!
    May 2016
    Massachusetts
    188
    Tks, pooldv. I noticed quite a bit of organic material at the bottom after the week away. Going to sweep and SLAM and see if the pool "resets".
