Thread: Overnight loss question
    Sep 2015
    Los Angeles
    31
    I am SLAMing my spa with a CYA of 40. So I take it up to 16. should I really only expect to lose 1.0 or less overnight?
    At what level can the CYA not protect that level of FC?
    1100 gallon gunite IG spa with vanishing edge and 300 gallon overflow basin. Cartridge filter, hayward variable speed pump, finished 11/15/15, Taylor kit,
    38,371
    Re: Overnight loss question
    That is correct, you should not lose more than 1ppm overnight which would indicate that there is nothing in your water consuming the FC.
    I do not understand your 2nd question.
    Sep 2015
    Los Angeles
    31
    I understood that after raising the FC to a high enough point you are going to lose FC because the CYA can't protect that much of it. I was just curious what that level was. Or am I just wrong?
    38,371
    You will always lose FC to the sun regardless of the CYA level. The CYA level will not protect X ppm of FC. Think of it more like the CYA will protect X % of the FC. The higher the CYA level, the higher the % that is protected from the sun and thus the higher the # ppm of FC protected.
    The higher you raise the FC, while the same % will be protected for a given CYA, you will lose more ppm to the sun.
