Thread: Hello from Warm & Sunny El Dorado Hills, CA
    Lomond's Avatar
    Jul 2016
    El Dorado Hills, CA
    2
    I recently bought a home with a pool and currently have a pool service. I am planning to discontinue the service and take this on myself. I do not know much about pool maintenance, but am eager to learn. It is great to know there is a support group out there!
    Jun 2014
    15,198
    Re: Hello from Warm & Sunny El Dorado Hills, CA
    Outstanding! Welcome to TFP! You're making a good move. Just make sure to start with the right test kit. I recommend the TF-100 (link below). Here is some more info that may help you:
    TFTestkits.net
    Pool School - Test Kits Compared
    Great to have you with us.
    Jun 2016
    Sacramento
    28
    Quote Originally Posted by Lomond View Post
    Congratulations and welcome! I am right around the corner in Rocklin. So we have similar climates (HOT!) and sometimes cold. I got rid of my pool guy about 2 months ago and my pool has been sparkling clear using the methods here. You won't go wrong.
    Hopefully the pool guy didnt mess up the pool too bad and put too much CYA in it. If he did, I would probably just use recommended doses of chlorine, be sure to not let it drop below the minimum (or else you're in BIG trouble if you get algae) and just let the water "splash" and run-out during the rains this year (hopefully we get some).
    That way, with our drought, you don't have to dump pool water.
    20k IG Irish Mist Pebble Sheen, Pentair IntelliFlo, Easy Touch, Clean and Clear 520, Solar Heating. Use Taylor K2006.
    Lomond's Avatar
    Jul 2016
    El Dorado Hills, CA
    2
    Hey Rocklin Neighbor- Thanks for the tips. I will purchase the test kit Texas Splash recommended (Thank you Texas Splash). This kit tests CYA. Hopefully my pool guy did me right maintaining the proper CYA level.
    Enjoy the cooler weather in Rocklin the next few days and jump in that pool when it heats up over 100 this weekend!!
    Salt Water Pool/Spa, 15,000 gal, In-ground, Plaster, 2 HP Sta-Rite Max-E-Pro Filter Pump, 3/4 HP Sta-Rite Max-E-Pro Cleaner Pump, 1 1/2 HP Sta-Rite Dyna-Glas Waterfall Pump, Sta-Rite System 3 Cartridge Filtration System, A&A Manufacturing In-Floor Cleaning System, Intellitouch i7+3 Control System, Yr Built: 2005
