Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: What is on the bottom of my pool and why does it come back everyday?!?!
    Jul 2016
    Florence, KY
    22
    PLEASE help. This is my first pool and I am a newbie. I have the Intex ultra frame 16'x48". It was the one that came with the all in one cartridge filter, pump, and salt water system. After a few posts on this forum it was clear I needed to upgrade that system. So I bought the 16" Intex Krystal 3000 gph sand filter with the salt water ECO system separate. I felt like this would keep my pool very clean. Well I just installed it 2 days ago. Everything looks pretty good but I have always got like this dirt like substance on the floor. I bought the delux Intex maintained kit with the vacuum that hooks up to one of my inlets. And yes it worked great and is very powerful with the new upgraded pump. And the outlet is much more powerful. But I vacuumed the whole pool on Saturday. Thought I had pretty much seen the last of a dirty floor but today boom it's everywhere?!?!? I don't even know what it is. Where it's coming from? But most importantly how to get rid of it for good!!! Posting pics soon. PLEASE help. I am also running the Intex hang over the edge pool skimmer that works very well.
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Re: What is on the bottom of my pool and why does it come back everyday?!?!
    What type of test kit are you using to monitor your chlorine levels? Also what is your main source for chlorine?
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Is it green? Slippery? Slimy? It is probably algae. Algae grows when FC is too low. The pool is also not sanitary when FC is low. It is very important to maintain FC above minimum at all times for your CYA, FC/CYA Chart. When FC drops below minimum the kill rate for bacteria, viruses and pathogens is too low to assure prevention of person to person disease transmission, especially in kids.
    I see you have trees really close to the pool. I have the same problem. I have had an algae outbreak this week, as my intex swg was blinking low salt, and I wasn't home, so when I got home, no chlorine. Anyway, I have been Slamming the pool for 5 days, and FINALLY passed the OCCT, but to my dismay, there was still some of this stuff on the bottom of the pool. Not nearly as much, but I'm wondering if it is pollen off the trees.... or something like that. Unfortunately, the trees are not on my property, or they would be gone!
    16' x 48" Intex Ultra Frame Above Ground Pool, 5,000 gal, 2800 gph Intex sand filter pump, Intex Saltwater Generator, TF-100 Test Kit.
    Jul 2016
    Florence, KY
    22
    Its like a fine dirt or pollen. I use the pool test strips. I'm still very new to all this chemistry so please forgive my ignorance. If it is pollen (which I think it is, why isn't my pump / filter picking that up?
    DFW, TX
    24,450
    No worries, we were all new once. I had a green Intex pool once! Or more than once.
    Do you have a brush? Brush the pool to keep it stirred up.
    Ditch the guess strips and get a good test kit. I use the TF-100 from TFTestkits.net. or maybe the TF-50. More here, Pool School - Test Kits Compared
    You need an FAS/DPD chlorine test so that you can do an Overnight Chlorine Loss Test to see if that is algae or not. If it is algae then you can kill the algae following this, SLAM
    Jun 2015
    Somerset
    26
    i get the same thing, i wish i put my pool in a different area. it has a lot of trees around it. That and constantly cleaning stuff out is irritating. Time for a skimmer upgrade lol13239098_1743377969275074_2739895244649285780_n.jpg
    Cypress, Tx.
    154
    It's Algae. I recognize it well.
    Intex 18ft dia. Ultraframe, 6500 gal. above ground Intex pool with Hayward C550 cartridge type filter and Intex Krystal Clear Ozone and saltwater system model ZS8110, Taylor K-2006 test Kit, Pool filter supplemented with Duda Diesel 1 micron filter bag
    Located in Cypress, Tx.
    Jul 2016
    Florence, KY
    22
    Quote Originally Posted by gtty View Post
    Well you're right. Today it's grown twice as bad. I put my ECO salt water system in booster mode as well as added Blast (non chlorine pool shock). I was going to go use the pool vacuum and suck it up and use the brush to break it up but now I'm kinda wanting to leave it and see what will kill it on its owe? So I know it's alge now. What next???
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    338
    i have the same stuff on the bottom of my pool. i got my goggles on and went down and looked at it really close. i even tried to get some in between my fingers. but as soon as i touched it, it just totally dissolved. there was no slickness to it, mine was actually a brown color. i thought mine was actually a little sand that was coming out of my filter. that was not it either. i came to the conclusion that it was pollen from the trees. some days it is worse than others.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    Cypress, Tx.
    154
    Quote Originally Posted by dejayssaleen View Post
    Here what I do. See what your CYA level in your pool is. Bring your pool up to shock level. If i remember correctly its 28 ppm chlorine for 70 ppm of cya. If it's a saltwater pool you shouldn't have your CYA below 70. Keep the free chlorine levels up according to the S.L.A.M. Method. I'm in Houston and with our oppressive heat that is what it takes. I run my Intex SWG 7 hours a day to keep Chlorine at 6ppm. Anything less and I get algae. Forget about that boost mode. It's worthless. Bleach is your friend for chlorinating your pool
    Your filter won't filter that stuff out unless you have a polishing bag that filters 1 micron. You can also use a Duda diesel filter bag on your return. That's what I use and it works well. The chlorine will dissolve it too overnight.
    Jul 2016
    Florence, KY
    22
    Thank you for your reply but again I'm a total newbie. And most of that looks like Chinese to me
    Probably mustard algae. Need to do a proper Slam.
    Support the site
    Cypress, Tx.
    154
    Pooldv above has the links to what you need to know. Read pool school and you MUST get one of the recommended full bore test kits to know where you stand regarding water chemistry. I use the Taylor K-2006 kit. Without the proper test kit you will spend multiples of what the kit costs and your water will still be green. There is basically combined chlorine which is essentially used up chlorine and free chlorine that can still sterilize your water. The el cheapo test kits test I believe for only combined. That test can read really hi in chlorine but your water will still be green.
    Also the 2006 test kit will test for all the other levels you need. One of the most important levels is cyanuric acid "CYA" or what is sold as Conditioner. This chemical keeps your chlorine from being destroyed by the sun and if the level is too low you can put gallons of bleach in your pool and it will be mostly gone by that evening. Because cya keeps the chlorine from being destroyed by the sun, it also slows down the chlorines ability to treat the water. This means you will need higher chlorine levels than you would need otherwise, but you still save money on bleach.
    The rest you can read about in pool school. I learned all of this the hard way, and so did almost everyone else here.
    Keep asking questions and we will all help you out.
    Someone correct me if I'm mistaken on my info.
    Jul 2016
    Florence, KY
    22
    Is the tests different for reg pools vs salt water pools?
    Same testing other than a salt test for salt pools.
    Support the site
    Cypress, Tx.
    154
    Same test except that you will need to test for salt levels in a saltwater pool
    Jul 2016
    Florence, KY
    22
    Are the test easy for a newbie? Can someone link me to them on Amazon?
    Cypress, Tx.
    154
    I'm sure you can do it. I think there are some videos on YouTube also.
    Amazon.com : Taylor K-2006-Salt Test Kit : Patio, Lawn Garden
  20. Back To Top    #20
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Please take a look here. TFtestkits.net has good value test kits. Pool School - Test Kits Compared
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
