Thread: Is this the correct polyquat 60 algaecide
    May 2012
    Allentown, PA
    219
    My pool is looking good, but I want make sure I keep the algae away. I want to add algaecide (the polyquat 60) and just am checking if this is the right product. Amazon.com : Kem-Tek KTK-50-0006 Pool and Spa 60-Percent Concentrated Algaecide, 1 Quart : Swimming Pool Algaecides : Patio, Lawn Garden Also where else is it available anywhere for cheaper?
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Is this the correct polyquat 60 algaecide
    That's the right stuff, but you should not need it if you maintain adequate FC levels at all times. You might be able to find it cheaper at a local store... but doubtful.
    Isolated Spa - 345 Gallons
    May 2012
    Allentown, PA
    219
    okay, thanks for the help and suggestions
