Thread: OCLT - Necessary? Alternative
    Jun 2013
    North Dakota
    5
    I always read how performing the OCLT test is necessary but I've never been able to do it. I live in the northern U.S. The sun goes down before I go to bed and rises before I get up (at least during the same months the pool is open). I've always just skipped this test, but am wondering if there is an alternative.
    21000g inground, vinyl. Maybe 30 years old.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: OCLT - Necessary? Alternative
    ITs the easiest and best way to check if your water is eating chlorine vs the sun burning it off... Removes a variable
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    38,547
    The OCLT is the only way to eliminate the sun as a source of FC loss.
    Sounds like you need to set you alarm clock earlier ... for one day ... go back to bed after if you must
