Thread: Super noisy pool motor affecting maintenance.
    Jun 2016
    Somewhere in the 405, OK
    8
    Hello, folks,
    Lately, I've been experiencing issues with the pool motor, as it has been running extremely loud. It's almost an plane blade propeller, making that whirring sound, and it feels as though any day now, I'll wake up to find that the pump flew away. It's also affected the manner in which I'm trying to SLAM the pool, as I've been adding chlorine, but I see little to no change. I'll turn the motor on, and it seems as though it's running, but there's little to no change when I try to clean it. I read a previous thread about pool motors, which was posted over three years ago; but I'm posting this here to see if these two issues (noisy motor, and pool maintenance) are co-related. Thanks in advance.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Super noisy pool motor affecting maintenance.
    Quote Originally Posted by jaydelrey View Post
    Not usually unless the pump is not pumping water at all. Can you feel water coming out of the returns?
    Post a set of full test results. More than likely your SLAM has not kept the FC at sufficient levels. How often are you testing and have you run a OCLT?
    Mark
    Jun 2016
    8
    Quote Originally Posted by mas985 View Post
    It is pumping water. I tried to clean the pump per the instructions that were offered on this site. So I can still be able to SLAM the pool in spite of the noisy pump motor? What could be the issue with the motor?
    Jun 2016
    8
    Since our last correspondence, it has stopped running altogether. It will come on for a few seconds, then stop. I'm guessing it's the motor.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Then it is probably bad bearings. You can either replace the bearings, the motor or the entire pump.
    Mark
