Results 1 to 9 of 9
Thread: Best way to add stabilizer
    Jul 2016
    Trevor, WI.
    9
    I'm looking for opinions on the best and most effective way to add my stabilizer. My method now is to make a slurry and add it to the deep end where the main suction is located. I was wondering if I could pour the granulars directly into the surge tank. Any thoughts?
    250,000 gallon outdoor commercial pool.
    Epoxy coated concrete(white)
    Sodium Hypochlorite disinfectant.
    Sulfuric Acid.
    2 Neptune-Benson sand filters.
    Jun 2014
    15,023
    Re: Best way to add stabilizer
    Initial recommendation deleted - based on residential pools not commercial. I need to defer to someone with experience in your large application.
    TomGallopavo's Avatar
    Apr 2016
    Hillbillyville, MO
    160
    I think most put it in an old sock and hang it in front of a return jet squeezing every so often.
    Spring 2016 Install, 24'x54" Saltwater LX AG Round Pool (13500 gal.), AquaPro 200 SQ. FT. Cartridge Filter System 2-HP 2-Speed Pump, Solaxx Saltron Retro Jet RJ Saltwater Chlorine Generator, Aqualuminator Above Ground Pool Light, TF-100 Test Kit w/ Borate and Salt, Well Water.
    Jul 2016
    Trevor, WI.
    9
    ​Thank you. Yes, I do have a large amount to add. I'm usually adding anywhere from 50 to 60 lbs at a time. The surge tank is unpainted concrete, if that helps.
    Sulfuric Acid.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I don't think you want it sitting on concrete or plaster for very long.
    Jul 2016
    Trevor, WI.
    9
    Ok, thank you. My thought was to find a bag big enough and suspended it into the surge tank. There is definitely enough turbulence in the water to dissolve it, especially when the gutters are dumping into it. Being a public pool, there are bodies in there from 6:30am to sometimes 10:00 pm, 7 days a week. I don't have to many options.
    Sulfuric Acid.
    DFW, TX
    24,450
    Suspended in some kind of bag or lots of knee highs would be fine. You just don't want it sitting on the surface.
    Jul 2016
    Trevor, WI.
    9
    ​Thank you. I will try to find something that will work.
    Sulfuric Acid.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Maybe a mesh bag for soccer balls... ?? something like that...
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
