I know I am jumping in here a little late, but when your pool went clear what was the FC reading? Also, I brought a black swamp back last year when I bought a house that had not used the pool in several years, took me a little under a week once I started following advice from this forum. Also it helped me to vacuum the deep area to waste with someone watching the waste water when it would turn brown I would pause till it cleared, I think that helped. Also you mentioned that dirt would come out the returns when filtering, which really should not happen unless you did not rinse after back-washing. so keep that in mind if things do not clear up soon. But in my way way of thinking you are probably correct that you FC was not high enough for SLAM. Good luck and will track to see your success.
