Results 1 to 8 of 8
Thread: Not sure if I have algae
    Jul 2016
    Birmingham, AL
    11
    First off, a huge thanks to this site and participants because this is the first question I've needed to ask.
    I'm a new pool owner (bought a house with one this spring), but I've been following the TFP methodology and found it to be simple.
    We had a new liner installed in May.I never SLAMed the pool, just added chlorine and other chemicals to balance it out. It has been pristine all summer.
    Last Thursday we had some significant storms that landed a lot of leaves and sticks in the pool. Ever since then, it's been cloudy, with a slightly yellow tint. I can still see the print at 8 feet deep, but barely. I don't think the FC ever went below 2, but in the loss of power and other craziness, it might have.
    I also recorded the pH at its highest level ever. It had been around 7.5, but it was measuring 7.8. I added some dry acid to bring it down along with some baking soda to take my TA to about 70. My current stats are:
    pH: 7.6
    TA: 70
    FC: 3.5 (has ranged between 2-5 all summer)
    CC: <0.5 (have occasionally measured it non-zero
    I have run the filter 24/7 since and run the Aquabot a few times too. There do seem to be pockets of something dark on the bottom, but in very few places. Is it time to SLAM? The bad news is that I'm leaving town on travel this afternoon. I'll be back all day Saturday and then leaving for a week on Sunday. Bad timing...
    20x40 IG Vinyl
    33000 gal.
    Taylor 2006 test kit
    Sand filter
    Aquabot Classic
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Not sure if I have algae
    Welcome to TFP!
    Well, the first question we always ask, what test kit are you using to get your numbers?
    The way we prove/disprove organics apcausing cloudy water is by conducting an Overnight Chlorine Loss Test
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Welcome to TFP!
    What is your CYA? How do you chlorinate?
    Jul 2016
    Birmingham, AL
    11
    I test with the Taylor 2006 kit
    I chlorinate with 10% liquid. CYA is 50
    20x40 IG Vinyl
    33000 gal.
    Sand filter
    Aquabot Classic
    May 2014
    Franklin, NC
    9,184
    OK, conduct and Overnight Chlorine Loss Test tonight.
    Support the site
    DFW, TX
    24,492
    Take a look at the FC/CYA Chart, FC needs to be maintained above minimum at all times.
    Jul 2016
    Birmingham, AL
    11
    I'm unfortunately on travel, but my wife confirmed that the pool is cloudier and greener today, so she's going to start a SLAM. Does anyone know if the higher chlorine would hurt the pool robot? I would assume it would be good to run it overnight? If it matters, the walls don't have any sort of slimy feel.
    20x40 IG Vinyl
    33000 gal.
    Sand filter
    Aquabot Classic
    Jul 2016
    Birmingham, AL
    11
    Update: My wife started a SLAM and it's going pretty well. Green is pretty much gone
    20x40 IG Vinyl
    33000 gal.
    Sand filter
    Aquabot Classic
