Results 1 to 9 of 9
Thread: Ecotech EZ motor failure
    Mar 2015
    Laguna Hills
    8
    I have a 2-year old Ecotech variable speed pool pump motor that just failed. The run/start button flashes green continuously and the other buttons and the display do not work. I tried a factory reset and power cycling, but that did nothing. The shaft turns freely when disconnected from the pump, so I am thinking it is an electronics issue. Does anyone have experience in repairing these units? Already tried Nidec (formerly Emerson) and the place where I bought the pump, but both were unhelpful.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Ecotech EZ motor failure
    Did you install a power surge protector when you installed the motor? If not, you may have a bad drive on your hands and unfortunately, they are not easily repaired unless you are an electronics wiz.
    Mark
    Mar 2015
    Laguna Hills
    8
    Quote Originally Posted by mas985 View Post
    No, I do not have a surge protector, but all other home electronics was functioning at the time the motor quit.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The number 1 reason VS drives fail is because there is a lack of surge protection. They are extremely sensitive to power surges. Home electronics survival means nothing.
    Mark
    Sep 2016
    Mesa AZ
    2
    Have you found the solution, I have same problem
    Sep 2016
    Mesa AZ
    2
    Quote Originally Posted by jrusher1 View Post
    Have you found a solution? I have same issue
    Mar 2015
    Laguna Hills
    8
    Still looking for a solution
    Maybe take it to a place where they do motor repair or electronics repair (tv, computer etc).
    Support the site
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,059
    I just install this. From my research this is the best for the buck. Hope this helps
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
