Thread: what to do about a leak?
    Jul 2016
    UK
    2
    So we got our first pool this year after spending weeks getting everything ready and and levelling out we started to fill it, it's about half way full now and we have noticed a puddle of water at the of the pool by one of the corners. We have mopped it up a few times and it keeps coming back and it is also wet under the pool in that corner, so we figured it must be a leak. We are just unsure of how to find the hole to patch it up, also we are worried it might be leaking from the seam as we needed to move it to level out some more so we moved it with some water in as we couldn't get the last little bit out (it wasn't even an inch of water though)
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: what to do about a leak?
    Vinyl liner?
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    13500 gal
    Casey's Avatar
    SW PA
    10,427
    You're going to have to get in the pool and start searching the area that is leaking. Put on the mask and start looking at the bottom of the pool slowly, back n forth and along the seams to see if you can find the hole or slit. Once you find it, cut your first patch a little bigger than the hole with rounded corners. Apply another patch bigger than the last in the same manner. Do this 3 times to ensure a good seal, especially if it's on a seam. Intex pools are notorious for seam failures. Some are worse than others.
    Good luck.
