Thread: Do I have the right filter system?
    Jul 2016
    Laura
    1
    I purchased a 27 ft. 17000 gal. above ground pool which came with a Waterway II cartridge filter system. I put the pool half in ground and half out, therefore the filter/pump system is located mid pool. The filter hardly has any water flow into the pool at all. Do I need a bigger motor or different filter system all together.
    LK FRAZIER
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Do I have the right filter system?
    Welcome to the forum!
    Without knowing the exact model of pump and filter, I can't help/
    Please follow these instructions: Pool School - Read This BEFORE You Post
    Mark
