Like many who have been posting, I am new to this business! I just set up my 18' pool in June, and clearly need a better way to clean debris off the bottom. The pump that came with the pool has no HP rating, and I can't even calculate it from the voltage and watts, since I can't locate the Wattage either.
My pump is: Krystal Clear Model 635T Filter Pump, 1500 gph
Is there a way to determine the horsepower rating for this pump? Can I determine if it will drive a small suction-type pool cleaner? It would't matter much to me if it just did the pool floor and not the walls.
Such as: Pentair K50600 Kreepy Krauly E-Z Vac Suction-Side Above Ground Pool Cleaner Blue/White
I am open to upgrading the pump if need be. The cartridges are pretty dirty after just a few days.
