Thread: Weeping Jandy valve at low speed
    Aug 2015
    Orlando
    116
    Just noticed that when pump is running on lower speeds, I've got some weeping from my closed-valve waterfall. Water continuously runs down the tile, noticeable enough it leaves ripples in the surface water. Doesn't seem to do it over 2500 rpm on the pump, but certainly does at 1700.
    Is there an easy fix for this? I've opened and closed valve several times, but it doesn't fix it. We only use waterfall when guests come over, or we need to aerate.
    I'm leary that if it continues I will get hardness buildup on the tile line.
    Thanks for any suggestions
    Phil
    ~9600 gal gunite pool, NEW July 2015; Pentair Intelliflo 2 VST pump; Pentair C&C 150 filter; Pentair Intelliclor IC40 swg; solar heat w/ Pentair Solartouch controller, screened. Taylor K 2005 test kit, FAS-DPD separate test, Taylor K1766 salt test
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    Is the water coming from the top of the valve or from the pvc connection. You can get rebuild kits for the Jandy neverlube valves.
    If it's the pvc, this may work. Leak-B-Goneā„¢
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    22,553
    Re: Weeping Jandy valve at low speed
    It sounds like the valve is leaking through. If that's the case, then as Carlos said, you can get a rebuild kit for it and that should solve the problem.
    Aug 2015
    Orlando
    116
    Quote Originally Posted by carlos31820 View Post
    Sent from my iPad using Tapatalk
    Not leaking at the valve itself, water is seeping out the waterfall, so the valve isn't closing tight.
    Thanks for the tip on rebuild kits, didn't know these were repairable.
    Phil
    Nov 2010
    Midland, Georgia
    353
    Yes, that's one of the big selling points of the never lube valves, you can replace the handle as well as the O-rings without needing to replace the valve body.
