Thread: OCLT Test
    Mar 2014
    Angleton, Tx
    91
    OCLT Test
    just wondering does the pump need to run all night for this test? Or can i turn it on 30 min or so before i test the following morning?
    Thanks
    IG Pebble sheen blue surf approx. 14k gallon, beach entry, 7' spa, 3.5 ton jumping rock/waterfall, Pentair 2hp whisper flo, booster pump, 520 cartridge filter, Stenner Econ T, 400k master temp heater, easy touch controls,TF-100 w/speedstir
    Jun 2014
    15,192
    Re: OCLT Test
    If it was in conjunction with a SLAM it would be running all the time. But if you are just performing an OCLT out-of-the-blue, then a 30 min mix prior to testing should suffice.
    Mar 2014
    Angleton, Tx
    91
    Re: OCLT Test
    That's what i thought, thanks
