Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Help, please
    Apr 2016
    Carriere, Ms
    16
    Help, please
    Hi everyone! My pool has been up since mid June and it has been wonderful! No water problems at all, until now! And it's a mess, I have algae bloom on the bottom and now on the sides, I did a testing this morning and this is what I have FC 15, CC 1, pH 7.2, Alk 80, Cal Hardness 0, CYA well over 100. I have no idea what to, and what to do first! Correct the Algae problem? which lord knows my FC levels are so high, correct the pH first? I'm afraid it's completely out of control! Can someone please, please help!! Thank you in advance!
    18' x 52" Intex Ultra Frame AG - Installed 05/22/2016 , 1600 gph Intex Sand Filter Pump , City Water, Taylor K-2006 Test Kit
    Jul 2015
    Georgetown/DE
    7
    Re: Help, please
    Not one of the experts, but you need to SLAM your pool. The issue is your CYA is too high. Your CYA could be over 100 that is as high as the test goes. You would need to drain off half of your pool and refill to get the CYA down and then SLAM the pool.
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Help, please
    In order to really maintain the pool, you need to complete a partial drain and refill to reduce CYA. Once algae is established and growing, FC of 15 won't kill it as fast as it will multiply. I would suggest 50-60% water replacement then retest your CYA. Hopefully that will get it down to 40 or 50 ppm and you will have much better luck managing your pool.
    Any idea how your new pool's CYA got so high so fast??
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Apr 2016
    Carriere, Ms
    16
    Re: Help, please
    Pool tool, my husband didn't want to use TFP methods and shocked with over the counter shock with stabilizer in it, attempting to try to get rid of the algae, and he also put chlorine tablets with stabilizer as well! Now he's looking at me to try and fix it. So now I'm going to try it my way the TFP way! Should I brush off the algae before draining? Refill then test CYA, should I Slam it then? Still concerned about the algae also? And if I do need to slam, how many gallons of bleach should I have on hand? I'm sorry so many questions, all new to me!
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Help, please
    Brush it, and if you can vacuum to waste.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jun 2014
    15,270
    Re: Help, please
    Okay then, once this is all over it sounds like your husband may owe you a nice dinner out. While you are draining some water, sure, you can scrub and sweep some to try and remove some algae dust and debris, but once re-filled you'll still need to SLAM. It will just work better. The amount of bleach required varies, but I'd have about 10 bottles ready just to start.
    Remember, since your CYA was well over 100, it may be sky-high closer to 200. You can try the dilution method as follows if you would like:
    Add pool water to bottom of sticker.
    Add tap water to top of sticker.
    Shake.
    Pour out half so mixture is to bottom of sticker.
    Add reagent to top of sticker.
    Shake.
    Test outside with back to sun and tube at waist level.
    Pour back and forth a few times to see if you get the same result.
    Double the result.
    From there, try to get that CYA around the 50 mark or so. At least from 50 you can still SLAM and once done your CYA will be in a good place for the summer heat. Before increasing the FC for the SLAM, don't forget to lower pH to about 7.2. Let us know if you have any more questions.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Help, please
    Brush the sides and floor of the pool and vacuum to waste. Mix a cup of pool water with a cup of tap water and test the CYA again. Read the result and double it to get a ballpark CYA reading. Use PoolMath to determine how much water to drain and refill. Test the CYA again after the pool is filled. Once the pool is refilled and the CYA is around 20-30ppm begin the SLAM process.
    Read ABCs of Pool Water Chemistry for information about basic pool chemistry. Feel free to ask any questions you may have. We're here to help!
    Love TFP? Become a
    TFP Supporter!
    Apr 2016
    Carriere, Ms
    16
    Re: Help, please
    Thank you all soooooo much! I will keep you posted!
    Casey's Avatar
    SW PA
    10,461
    Re: Help, please
    Definitely read pool school. We want to help you but you must first help yourself. There you will find a SLAM article. Make sure you retest the CYA before you move forward with the SLAM.
    P.S. Fire that pool boy!!!
    Apr 2016
    Carriere, Ms
    16
    Re: Help, please
    Hi Guys, drained about 60% of my water and refilled my new numbers are FC 5.4, CC 0.2, pH 7.4, TA 100, CYA high at 80. I've read pool school and SLAM info I know to adjust the pH with 8oz of Borax, before I start Slam, which I calculated 2.63 gal of 8.25 bleach to get my FC to 31. But, what about the CYA still being at 80?
    Jun 2014
    15,270
    Re: Help, please
    If you're about to "SLAM", then you're correct that with your CYA of 80 you need to reach an FC of "31" and keep it there. Your pH is 7.4, so you don't want to add borax or you'll make it go higher. You want to use muriatic acid to lower it to about 7.2 BEFORE raising the FC. Adjust pH first, the crank that FC up to 31.
    Apr 2016
    Carriere, Ms
    16
    Re: Help, please
    Thank you Texas Splash, I followed the pool math calculator that said min pH 7.5 so that's why I thought I should increase it! So do you think it's ok to slam with a CYA of 80? I really don't want to drain again��
    Jun 2014
    15,270
    Re: Help, please
    You can do a SLAM with a CYA of 80 - sure. Just takes a higher FC level, but you can do it. When you look at the SLAM page, you'll see that you are required to "lower" pH to about 7.2 before starting. That's because once you elevate the FC for the SLAM, you won't test pH anymore because the high FC gives-off a false pH reading. So yes, adjujst pH to 7.2 before increasing the FC to 31, then you're ready. Good luck!
    Apr 2016
    Carriere, Ms
    16
    Re: Help, please
    Here we go! Thanks!
    Casey's Avatar
    SW PA
    10,461
    Re: Help, please
    Keep that FC no lower than 31ppm. And goooooooooooo!
    Apr 2016
    Carriere, Ms
    16
    Re: Help, please
    I added the amount of bleach per the calculator and Just checked FC is now 40, I don't understand, did I do something wrong?
    tucsontico's Avatar
    Mar 2014
    202
    Re: Help, please
    Quote Originally Posted by Janel View Post
    Nope! Higher is just fine! Just keep testing every 2-3 hours and do NOT let the FC fall below 31 PPM! The SALM process can take awhile, so open a can of POP (Pool Owner Patience) and keep on SLAMMin' until you can pass the OCLT. Good Luck!
    19,500 gal, 16' x 38' PebbleTec IG Pool, Built 4/2013; Pentair IntelliFlo VS 3050 3 HP Pump, Pentair Intellichlor IC40 SWG, Pentair IntellipH, Pentair 520 sq ft/150 GPM Cartridge Filter, A&A In-Floor Cleaner, Dolphin Nautilus Plus Robot (aka "Robbie"), Pentair EasyTouch Power Panel w/ Quick Touch 4 Remote Control, Autelis WiFi controller, Clear 12 mil Solar Cover on Presto SS Reel, Taylor K-2006 Test Kit.
    Apr 2016
    Carriere, Ms
    16
    Re: Help, please
    Thanks! Trying to figure this out is driving me crazy!
    tucsontico's Avatar
    Mar 2014
    202
    Re: Help, please
    Take deep breath, don't lock your knees, you've got this under control. Your algae problem didn't happen overnight and it won't get clear overnight. Like I said before, open a can of POP and keep on SLAMin'!
  20. Back To Top    #20
    Casey's Avatar
    SW PA
    10,461
    Re: Help, please
    Your gallonage is probably less than you calculated.
