Results 1 to 10 of 10
Thread: Can I swim yet?
    Jun 2016
    West Lafayette, Indinana
    14
    Can I swim yet?
    Current readings as of this morning...
    5 ppm FC, 0.5 ppm CC
    300 ppm CH
    8.0 pH
    340 TA
    30 cya
    I filled up pool just two days ago so trying to get this under control.
    I think my numbers are okayish? pH is high because I'm trying to lower the TA values... But if I get that down to under 7.8 is my pool okay to swim with the TA number high? I also have a green tint in the water, which I think is from iron content. Water is clear, I can see the bottom though. But is water being green tint safe to swim?
    I also had thread in the "The TFPC method" page but I should probably stick to the "Just Getting Stated" for a while...
    16'x48" Coleman AGP Filled 2016-07-16. FlowClear Filter Pump #90401E (???? gph?), Intex LED Fountain.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Can I swim yet?
    Safe to swim criteria:
    1- Can see the bottom of the pool clearly.
    2- pH between 7.2 and 7.8
    3- FC less than shock level for your CYA (12 in your case)
    You're good to go for swimming, TA will come down as you continue to maintain pH. Probably high acid demand, fast pH rise for a while.
    Isolated Spa - 345 Gallons
    Jun 2016
    14
    Re: Can I swim yet?
    Cool! So the green tint isn't bad since it's not algae?
    30,432
    Re: Can I swim yet?
    Well, it is certainly safe to swim. That said, if your green tint is algae it is a lot easier to get rid of than if it is iron.
    A pic and posting complete test results would be very helpful. Enjoy your swim and we'll work on the green when you are ready.
    Jun 2016
    14
    Re: Can I swim yet?
    Pretty sure it's not algae. I unknowingly did a OCLT test last night and my FC level remained the same.
    Last night 8:30pm
    5 ppm FC, 0 CC
    300 ppm CH
    7.7 pH
    360 TA
    and then these numbers from this morning in post above
    300 ppm CH
    8.0 pH
    340 TA
    30 cya
    Jun 2014
    15,255
    Re: Can I swim yet?
    Those look like relatively good test results with the exception of the elevated TA you are already aware of. So if we now assume the green tint is metals/iron, you'll want to see if you can capture as much of that as possible while it's active and precipitated out in the water. Have you tried adding some paper towels or cotton material to the skimmer? If it's iron, the material/towels should begin to change to a brownish color as it grabs the iron. If you've ever added algaecides, it's possible the tint is from copper. With either metal, replacing with non-metal water is the most ideal, but we know that's not always feasible. So you try to remove as much as you can physically, then move-on to chemical treatment. Keep the FC on the low end, and also keep the pH in the lower 7s as well. (That one is tough right now while you try to lower TA though).
    Your next and most reliable method of metals management is to add sequestrant to the water and replenish it periodically. Sequestrant is a chemical that binds to the iron in the water so that it can't form stains or turn brown. Sequestrant breaks down slowly, so you need to add more regularly. ProTeam's Metal Magic and Jack's Magic the Pink Stuff (regular) are some of the top sequestrants. You can also find other brands with similar products, some of which are noticeably less expensive. Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective.
    You might also want to review the TFP Pool School - Metals in the Water and Metal Stains page for more info.
    Jun 2016
    14
    Re: Can I swim yet?
    I don't have a skimmer, but I did put a microfiber towel over one of the two water outlets. I was tempted to do both but was worried about burning up my pump. Curious to see what the towel looks like when I get home from work.
    When I rinsed out the filter cartridge this morning it was icky brown... My city water is gross. The pool fill water even went through my whole house water filter... which now that I've put 5000+ gals though it probably needs to be changed again...
    The sequestrant stuff looks interesting... Will have to hit up the pool store and see if I can pick some of that up. I didn't see anything like that at the HDs, Lowes, or Menards around me...
    Jul 2016
    Bushnell/FL
    21
    Re: Can I swim yet?
    I too am new to all of this, but i have been fighting with iron for weeks now. We did the towel over the intake parts, covered both, and changed the towels out every hour for DAYS. It helped some. But really, until you let the iron settle and vacuum it out, it will stay green.
    That is my pool 48 hours ago after my first round of vacuuming.
    This was this morning after about 5 vacuumings. This afternoon, it was clear! I couldnt believe it! Get a vacuum! It truly is what makes the difference with iron!
    Colmen Above Ground 18'x48"
    Sand Filter
    Very first pool! Any and all help appreciated!
    Jun 2016
    14
    Re: Can I swim yet?
    Hmm, so do you think I should stop the pump to let the iron settle? I'm still trying to bring my TA down so I guess I can't do both at the same time...
    Here is my pool so far... Got my TA from 340 to 300 in about 9 hours today...
    And the towel also after about 9 hours.
    Jul 2016
    Bushnell/FL
    21
    Re: Can I swim yet?
    Yup. Let it sit over night. In the morning, the water will be crystal clear, but all the iron will sit on the bottom like dirt . You have to vacuum out into the yard, not into the filter. Then fill the pool up, and do it again, and again, and again. Today (day 4) i could finally vacuum into the filter and then backwash it. So i didnt lose so much water.
    Sand Filter
