Results 1 to 13 of 13
Thread: pre-filter or cartridge cover for dog hair
    Jun 2016
    Florida
    9
    Hey All,
    First. Thanks!
    I have been researching and learning from the forum for the last couple months (sorry for not saying hi earlier) and I have really learned a ton about managing my pool. For example, I bought the Solaxx PH Tek based on feedback here to help keep the PH in check because the new cement and plaster is/was requiring acid at a ridiculous rate. I have a life other than adding acid twice a day. Anyway, thanks for that.
    One thing I can't find is good info on keeping dog hair from clogging up the filter cartridge. It takes a LONG time to rinse the cartridge of dog hair even a good direct hose sprayer. My dog loves to swim, and even when not swimming the hair on the pool deck usually finds its way to the pool bottom before I can sweep it. Of course, I have the skimmer hair net and try to vacuum after the dog swims. Much of the hair still falls to the main drain skipping the skimmer sock. I looked at adding a hair/lint filter before the cartridge but the cost is prohibitive. I also looked at maybe adding super lightweight foam/sponge material to the pump basket, but I am A) scared to mess with the pump basket in this fashion and B) not able to find a good solution that is fine enough to trap hair but will not add a bunch of material to the pump basket reducing its usefulness. I also looked into foam cartridge covers like the one you would see on an air filter, but reading up on the materials I expect it would break down quickly with the chlorine eating at it all the time.
    What I did find is that some folks here like 3dogowner (how do I tag someone?) mentioned using a nylon stocking over the cartridge filter, but didn't see any feedback about how that is working out for them. How is it working out for those that tried?
    If you have a great solution for this please let me know.
    12,000 gallon gunite/plaster/pebbletech, spa with waterfall, sundeck with bubbler. Pentair Easytouch & Screenlogic, Intelliflow VS, SWG, CC150 filter, AquaCal heater, Solaxx PH Tek. Screen covered pool cage, travertine deck.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: pre-filter or cartridge cover for dog hair
    Welcome to TFP!
    Cheap hair nets on amazon over your skimmer baskets will do wonders. Disposable Hair Net, Spun-Bonded Polypropylene, White, 100 per Bag: Science Lab Hairnets: Amazon.com: Industrial Scientific
    So cheap you can likely toss them after then get some hair on them.
    Isolated Spa - 345 Gallons
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Hair net....
    Cheap on amazon
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Aug 2014
    Houston tx
    2,524
    Hairnets are good! I think another forum member uses skimmer socks for when her grand dog visits because the are a finer mesh and let less dog hair through. But, they are more expensive and you might not want to use them daily.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jun 2016
    Florida
    9
    Yes I have the hair nets but too much hair is sinking to the main drain. My question is about what are people doing about hair that makes it to the pump and filter.
    Jul 2015
    Jacksonville Florida
    18
    MasCerveza
    I wonder if you could use a hair net on the filter just before the pump, mine filters both the main drains and the skimmer, mine always stays cleaner than the skimmer filter. I too have a hair problem from my long haired GSD, she loves to swim with my wife and the grandkids, I am going to watch this thread to see if the hair nets or something equivalent could be a solution.
    Keith
    Sun Pools fiberglass Rio, 11,600 gallons, Installed 11/2015
    Hayward 3/4 hp super pump, Hayward 150 cartridge filter
    Taylor K-2006 test kit with speed stir
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    As someone who has burned through 4 pumps due to pine needles, I can give you the thing that will be the best thing you've ever learned! I use knee high pantyhose in the pump basket! It has saved me from burning up pumps for good! I just throw it away and put another in about once a week! And believe me...it is almost full in that amount of time so I can relate to your issue! Just slit places for the handle to go through and you are good to go! I use skimmer socks in the skimmer but they are a little expensive to use in the pump basket and throw away weekly. Give it a shot!
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    Jun 2016
    Florida
    9
    OK great. Glad to hear someone else is manipulating the pump basket as I was worried that would be an issue. I have a pentair pump with a basket like this:
    I need to figure a way to put the hair net or pantyhose inside the basket and under that hole in the side of the basket. Otherwise it will block that hole and this is where the water enters. There is no lip on the inside to hook the hairnet under and around so I may need to create one with some PVC. Ill order a junk quality basket online and play with it and report back.
    Last edited by MasCerveza; 07-19-2016 at 06:33 AM. Reason: made image smaller. took up whole screen
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    Would you consider turning off the suction to your main drain and letting your vacuum get the debris on the bottom? Many don't even have main drains. Then all of the debris will go to your vac or to your skimmers. And if your skimmers are pulling with more suction, they will skim the water faster allowing less debris (fur) time to fall to the bottom. If you have a suction cleaner this would still be an issue though. A pressure side vac or robot would work.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Quote Originally Posted by MasCerveza View Post
    Hmm..my pump basket doesn't look like that..it's closer to this...Tuesday, July 19, 2016.jpg
    so that it sits below the intake pipe. Maybe you could find one like this that will fit your pump?? Poolcenter has a bunch of different ones and they aren't expensive at all... Pool Pump Baskets - Quality Replacement Baskets from PoolCenter.com
    10,700 gal IG vinyl
    2 skimmers
    Jun 2016
    Florida
    9
    Quote Originally Posted by bmoreswim View Post
    I don't have a vac except the manual one. It does have a skim plate so I can vac to a hair net. In which case the manual time vacuuming probably won't save me time compared to extra filter cleaning time. I'll still try this next time the dog goes in to see how much hair falls or is caught by my skimmer.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    Most of our dogs hair tends to float or that which does sink tends to clump versus going into the main drain.
    Jun 2016
    Florida
    9
    My black lab has pretty course hair so some of it sinks quick. I'm likely too buzzed or lazy to address it in the moment....
