Results 1 to 7 of 7
Thread: Triton Sand Filter - pump stopped working
    Jul 2016
    Gainesville
    4
    Hi, I have a 21,000 Gal, Marcite/Granite Pool. I am a new pool owner and am still trying to become familiar with the ins and outs of pool care. We left on vacation for 2 weeks and had someone care for our pool, but on our return when I try to turn the pump on, it runs dry. I have refilled it with water and usually hitting the reset button works, but not this time. I also tried letting air out by the air release valve on our Triton Sand Pump and when water starts to run I close the valve and start it again. I did this three times, each time I let the air out, it took about 5 - 10 min. for water to start running through the valve. Could it be possible that I did not let all the air out and should have let it run through longer? Any help is appreciated. Have a great day!
    Happy Swimmer
    21000 Gallons - Marcite/Granite Pool
    Florida
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Triton Sand Filter - pump stopped working
    Hi, welcome to TFP! Could you post a picture of your equipment pad and any valves you have on the plumbing lines? That could help us troubleshoot your problem.
    Love TFP? Become a
    TFP Supporter!
    Jul 2016
    Gainesville
    4
    Here are a few pictures, let me know if there is anything else you need. Hope pics go through okay. Thanks for your help.
    Happy Swimmer
    Florida
    Jul 2009
    Houston, Texas
    9,376
    How high is the water level in your pool? If I understand correctly, the pump doesn't stay primed and you get a lot of air in the pump pot?
    Love TFP? Become a
    TFP Supporter!
    Jul 2016
    Gainesville
    4
    Water level is high, about 1/2 inch under the top of the tile that goes around the pool. When I turn it on there is a tiny amount of water that runs out, but then the water stops flowing completely. Could there be a clog I can't see or something?
    Last edited by PoolIssues123; 07-19-2016 at 09:46 AM. Reason: Adding additional info
    Happy Swimmer
    Florida
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Have you put a hose in the pump basket to fill it up before trying to prime the pump?
    Either there is a clog or a valve stopping the water flow to the pump. Or, more likely, a suction leak that is sucking air into the pump. More here about tracking down a suction leak, Pool School - Suction Side Air Leaks
    Jul 2016
    Gainesville
    4
    Tks for all your help. i did finally figure out the issue. The o-ring was off the strainer lid. I put it back on and let the air out quite a few more times and that was all it needed. Glad it was an easier fix than I thought. This is a wonderful site and I'm sure I will learn everything I need to know when it comes to maintaining my pool.
    Thanks again,
    Happy Swimmer
    Florida
