Results 1 to 9 of 9
Thread: Vacations
    May 2009
    Seminole, FL
    71
    Vacations
    What do people normally do when they leave for a week or so on vacation? Do you 'shock' the pool up to a certain point and hope for the best? I try to maintain my FC at 4-5ppm, it seems to drop maybe 1ppm per day (I do have pucks that I use to help maintain it as well, but I don't use many, just have it turned on low). So anyways, do people just add enough chlorine to get it up to 12 or more and when they get back it should be back around where it should be?
    ~13000 inground plaster
    150sq Ft Cartridge Filter
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Vacations
    you can shock which will help, but it probably won't be where it "should be" because you lose more when you add more. JasonLion has talked about that recently but I don't remember enough about it to search for the post. if your cya is ok, you could add more pucks and dial it up higher. you could use a polyquat60 algaecide. you could add borates for the algaestatic effects per the sticky in the chemistry 201 forum.
    Re: Vacations
    For up to a week, it works to shock the pool and cover it with a solar cover, especially if you have your pump on a timer and there aren't any major storms. If you have a chlorinator (puck feeder) and your CYA level isn't too high you can use that instead of shocking and then you don't need the solar cover (though without the cover you are more at risk of the skimmers getting clogged).
    For longer periods things get less predictable.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Vacations
    I agree, the other downside of not covering is evaporation, and then the water level could drop below the skimmer and you could suck air.
    I usually shock, cover and I'm good for a week.
    Jan 2009
    Cupertino, CA
    1,966
    Re: Vacations
    Or put some pucks in a floater if you don't have the inline thingy. Two pucks works pretty well for a week, in my pool, with a solar cover.
    --paulr
    BBB "Intermediate Swimmer"
    May 2009
    Seminole, FL
    71
    Re: Vacations
    I do have an inline puck dispenser (For lack of a better word.. lol). But I am trying to limit the use of the pucks. I suppose it wouldn't hurt to just turn it up for a week if I am gone. Just trying to plan ahead.. don't have any vacation plans yet..
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Re: Vacations
    I just came back from a 2-week vacation and I used this to keep the water level and I made a bleach delivery system dosing 32 oz/day from a peristaltic pump. I ran all of this for 3-weeks before going away with no problems. The pH was a little high though at just under 8.
    Leaving for an Asia trip tomorrow for another 2-weeks so I set it all back up again.
    If you are wondering I left the skimmers on low.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Re: Vacations
    maybe you could have someone add bleach every other day with the dose based on your historical daily FC loss...
    25,000 gal IG Utopia pool/Raypack gas heater/BBB
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Vacations
    Quote Originally Posted by AV8TOR
    That's important. Run it while you are there so you know how it will behave when you are gone.
