Results 1 to 7 of 7
Thread: pump and filter size?
    Jul 2016
    Trinity Tx
    4
    Hi just have a couple questions! First let me start off with the pool size, its 24' AG 13500 gallons, 1 1/2 hp hayward power flo lx pump, 175 lbs sand filter 1.8 ft filtration area 19". Now do i have the correct pump and filter combo? Cant seem to get my water clear! My chemical readings are
    FC 5
    PH 7.6
    TA 100
    CYA 40
    Really would like some help
    Pool Newbie! 24ft above ground pool. 13500 gallons, 1.5 hp hayward power flo lx pump 70 GPM, Hayward d dream line high rate sand filter 45 GPM filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: pump and filter size?
    Welcome to TFP!
    Cloudy water is usually a water chemistry problem and not a pump/filter problem. Perform an Overnight Chlorine Loss Test to see if there is some algae brewing in the pool. If there is then SLAM to kill it. You will need a good test kit to do those. I use the TF-100 from TFTestkits.net. It is the best value as shown here, Pool School - Test Kits Compared
    Jul 2016
    Trinity Tx
    4
    I see, also wanted to know if my pump and filter were compatable, would you happen to help out? My pool is on its 3rd day of doing the slam method. It has cleared up some just a little cloudy, im using just regular test strips, and oto drops. I know they arent the best, and also started the bbb method and my borate level is at 50ppm.
    DFW, TX
    24,485
    The pump is bigger than needed. If it is 2 speed then run it on low. A 3/4 hp 2 speed pump would be better if you are thinking about a new one. A bigger filter is always better but yours is OK. 22" or 24" would be better if you are shopping.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Despite it's name, the PowerFlo LX is not a very powerful pump. On that filter and typical above ground plumbing, the pump will probably only produce about 45 GPM. I wouldn't worry about it unless you see debris coming out of the returns.
    Mark
    Jul 2016
    Trinity Tx
    4
    Quote Originally Posted by pooldv View Post
    thanks for the advice i'm going to give it a couple more days and see if it clears up/ if not then a new pump and filter it is.
    Quote Originally Posted by mas985 View Post
    i used some d.e. sand filter aid and didnt see any come out of the returns. I'm going to give it a couple more days for the pool to clear up. Just started the bbb method and started the slam method going on the 4th day. pool was mustard green now its blue but cloudy. thanks for the advice
    mas985's Avatar
    Pleasanton, CA
    11,737
    Have you done a complete SLAM? Pool School - SLAM - Shock Level And Maintain
    The algae might still be alive.
    Mark
