Thread: What is the right way to use a pool heater?
    May 2016
    Toronto/Ontario/Canada
    68
    Hi everyone, I have a natural gas heater 250k BTU and a pool size 21k gallons. Our average summer weather temperature is in the low 70s and I do not have much direct sun hitting the pool. I am wondering what the best way to use the heater is. i.e. do I keep it on always and set it to the desired temperature (82-84F) and just let it regulate itself or do I keep it off most of the time and only turn it on when I know we plan to use the pool? Our pool usage is best described as inconsistent. Also please note that I mostly keep the pump running 12 hours a day only and usually at night. Your thoughts are much appreciated!
    In Ground Chlorine Irregular Shape (21,000 gallons), Cartridge filter Sta-Rite S7M120, Pentair 342001 SuperFlo VS, Vinyl Liner , Gas Heater Raypak P-R265B-EN, Test Kit Taylor K-2006, Filled with Tap Water, NO Spa, Several large trees towering the pool, Pool and equipment several years old but look in reasonable shape
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: What is the right way to use a pool heater?
    Do you have a solar cover? That will help a lot to hold in the heat overnight. Also, I would run the pump disputing the day rather than at night. Running the pump at night moves water through cooler pipes and cooler air. With a cover I would be inclined to keep it warm, without a cover I would heat it as needed.
    May 2016
    68
    Thanks DV!
