Thread: Which Intelliflo VS pump?
    Jul 2016
    Dakota Dunes, SD
    1
    It's time to retire my Century Centurion 1hp pump. It connects to a Hayward SP2607X10 filter basket and housing with 2" PCV plumbing. Supposedly there is a Pentair Intelliflo VS pump only, that is a bolt on replacement. I cannot find it. The salt water pool is just under 26,000 gallons (16x36 Inground) and 3hp would be overkill. Does anybody have a pump part number that will work for my setup? Also, when I unbolt the Century, don't I need new seals for the new pump? Any idea of a part number for those? Thanks.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Which Intelliflo VS pump?
    Mark
    Apr 2015
    Sag Harbor, NY
    21
    I am not sure I would get hung up on hp. I have the following pump. It has four speeds preset and then a largely infinite number of speeds with a system controller, where you can set the rpm. Being as your in SD, do you have a heater? Even better. Based on what I can see, these variable speed pumps are all larger hp. I had an old Hayward and its night an day.
    http://www.poolsupplyworld.com/penta...IGoaAoEA8P8HAQ
    Pool: 40k gallon pool shaped as a trapazoid. 10ft / 3ft deep
    Filter: Starite S7MD60 / Pump: Pentair Inteliflo multi speed pump /Robo Cleaner: Kreepy Krauly 830
    Pool heater: Rheem PM m336a (Legacy) / Control: Pentair EasyTouch PL4 Control
    Light: Pentair IntelliBrite 5G White
