Thread: What bleach?
    Jun 2016
    San Diego, CA
    31
    What bleach?
    Hello everyone,
    Exactly what type of bleach is good to use? Any particular brand?
    Salt water 28,000 Gal Pool with 1,200 Gal Spa
    Satin Matrix Pebble surface
    Pentair Intellichlor Salt Chlorinating system, Pentair Intellifo Variable Speed Pump
    Pentair 400,000 BTU heater, Dolphin DX5S Robotic pool cleaner
    750 sq foot Solar Pool Heating, Rock Grotto with waterfall
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: What bleach?
    Welcome to TFP!
    Any brand is fine as long as the percentage is marked on the bottle. I use the store brand concentrated bleach, 8.25%, from the grocery store. No scented or splashless. Just plain old bleach.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: What bleach?
    I have found that if it doesn't display 8.25% it is usually much less. Stick with concentrated bleach...no scents, and never the splash less type.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jun 2016
    San Diego, CA
    31
    What bleach?
    Thank you for the quick reply. Also my jacuzzi that's attached to the pool has some algae growth, is it ok to put about 1/2 gallon in it? It's about 1200 gallons.
    Previously, I would put some granular chlorine (cal hypo) but now after reading on this forum I realize that was wrong to do.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,278
    Re: What bleach?
    Welcome to TFP! Good to have you here
    Have you got your TF100 test kit on the way? Only way to go.
    You're going to need to SLAM to clear up the algae, and don't sweat, it's not that tough and you can keep swimming.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jun 2016
    San Diego, CA
    31
    Re: What bleach?
    Thank you and yes I've ordered the TF100 kit!
    I was thinking of just adding chlorine, scrubbing the walls then using my vacuum to drain the water and refilling back with pool water.
    My pool water is crystal clear.
    Also do you think maybe I'm not circulating the water enough, currently my timer is set for 1 hour to mix jacuzzi water with the pool water daily?
