Results 1 to 10 of 10
Thread: Hayward super Pump fitting
    Hello
    I have a Hayward Super Pump Model # SP2610X15. The outgoing connection which sits at the top of the pump had a leak, I took it off and re taped it and set it back in. Still leaking, I found it had a crack on the inside along the threads. I bought a new replacement compression fitting which says it replaces Hayward SP 1485DA and put Teflon tape on it and installed it. Now it still has a small leak but is better then before. I'm thinking it should have either a gasket at the top where it meets the pump body or an O ring at the bottom because it sits pretty flush with the housing. Is this possible?? or do I need to just snug it up a little more.
    Thanks
    Tom
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Hayward super Pump fitting
    Use pipe dope designed for plastic pipe.
    Thanks John.
    I assume the Teflon tape will come off then correct? I have never used pipe dope
    Tom
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by tpm
    Thanks John.
    Yes, take the Teflon tape off before usinf the pipe dope.
    I used pipe dope on PVC for the first time last weekend. Worked like a charm! It wasn't called "pipe dope" at HD; was located near the PVC glue.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    good to know (HD) that's where I'll be going. Thanks
    Tom
    Apr 2009
    Central Minnesota
    74
    I have always used clear silicone that comes in a tube that you can obtain from any home building store or Walmart. Works like a charm.
    18' X 36' X 4.5' vinyl oval in-ground 17K gallons, 250K BTU Pentair Master Temp NG heater, 1HP Hayward Super Pump, Hayward S200 sand filter, Hayward Pool Vac, Extreme mesh safety cover, TF-100 test kit.
    alben
    Just where would you apply the silicon? at the top of the fitting, bottom, or on the threads? Would you use it with the teflon tape? Right now I don't think it is leaking so I won't disturb it. But if it does maybe the silicon can be an easy fix.
    Thanks
    Tom
    Apr 2009
    Central Minnesota
    74
    I apply the silicone to the threads. As you screw the fittings in, the silicone redistributes itself and eventually you wind up with a bead at the top. I use silicone on almost all screw fittings. Silicon also works well for the pressure gauge on the Haward multiport valve. You don't have to turn the gauge in as far. (I once cracked a multiport valve by using Teflon tape with a gauge and overtightened). My experience has been that Teflon tape creates a seal by making the fittings "tighter", which adds extra outward stresses. Whereas silicone makes a seal by having a pliable substance in the pipe groves, without causing stress. Also silicone makes for easier disassembly in the future. So I now use Teflon only on metal to metal surfaces, and use silicone on plastic/composite surfaces.
    As for unions, where things are meant to come apart, I apply a liberal amount of petroleum jelly (Vaseline) to the rubber seal areas and to the threads of the coupler. Makes for an easier disassembly in the future.
    Very good information Alben. Sorry but one more question... Do I wait for the silicon to dry before starting the pump back up or just apply and start?
    Thank you and if it should start leaking again that is what i will do
    Tom
    Apr 2009
    Central Minnesota
    74
    I have always waited for the silicone to dry overnight.
