#1 My new 24'x48" round above ground pool needed to be dug into a slight incline to be level. The deepest part is about a 1'4" deep and it slowly tapers to level. I have read so much about backfilling with dirt, to not use dirt, to use/not use rock, to tar the below grade part, to put down plastic, and everything else. Where do you stand on this issue?
#2 I read a little about running the pump. Should i not run my pump all of the time? Is there a time you want it running and time to have it off, daytime / evening)?
