Thread: Repair crack in fitting
    I over-tightened the fitting/union that connects my skimmer pipe to the pump housing basket and it cracked in half. I really need to put the two pieces back together as it would be much easier than getting a new end to my pipe. I tried using Waterweld which is a putty that supposedly hardens and it didn't work. I tried another application of it, but I have little hope. Is there another solution?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Repair crack in fitting
    Replacement is the way to go in this situation.
    Support the site
    How do I replace it? Can I just buy the piece that cracked (not sure what it's called) or do I have to replace part of the pipe?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    You need to order a new union. Yes, you'll have to cut the PVC and do some plumbing.
    Here is a how to that shows how to do some plumbing, How To Replace a Pool Pump With An Energy Efficient Pool Pump - INYOPools.com
    Thank you both for the replies. My plumber is coming out tomorrow evening to fix it as it looks a little out of my comfort zone.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by illtiger1 View Post
    Great! It's the sign of a smart person who knows their limitations and brings in experts when necessary.
    Support the site
