Thread: Hayward Booster Pump Replacment Issue
    May 2009
    Langhorne PA
    2
    Hi, this site is great and I am really happy to be a part of this. I have a 15k concrete pool. I live in the NE area so when I opened the pool the booster pump would not kick on. I saved a bunch of money purchasing a new Hayward 6060 booster pump on eBay and now I am embarking on installing it myself. It looked easy enough with flexible hosing being used on the front portion but then I noticed hard PVC piping on the top. So I stopped and put everything back together and am now asking for advice on how to convert the 1" PVC pipe connected on the top to flexible piping to connect to the top of the new pump?
    1) 20,000 Gal, 2) DE 3) IG 4) Plaster
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Hayward Booster Pump Replacment Issue
    Flex PVC would be a good choice. It uses standard PVC fittings and solvent so can be joined to standard PVC pipe. It may be available at some Home Depot or Lowe's stores, or you can order it at http://www.flexpvc.com/cart/agora.cg...VC_Pipe_1_inch
    By the way, welcome to TFP!
    May 2009
    Langhorne PA
    2
    Thanks for the quick reply. So that I am clear. Should I cut the pipe at some point and then attached the flex pipe to both end? I have attached some pictures to add more information. Thanks again for your help.
