Thread: CYA dropped?
    Jun 2016
    Ithaca, New York
    50
    CYA dropped?
    Hi all,
    Today when we tested the pool, the CYA was 48. It had been at 80, right where it should have been. Why would it have dropped? PoolMath says to add stabilizer, is that correct? Will that change other results?
    FC 7
    CC 0
    pH 7.8
    TA 200 (I know this is high)
    CYA 48
    Intex round pool, 18' x 48"
    Cartridge filter, 1500 gph
    SWG
    Well water
    Full sun
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Re: CYA dropped?
    How are you testing that you got 48 as your CYA level?
    Support the site
    Jun 2016
    Ithaca, New York
    50
    Re: CYA dropped?
    With the Taylor test kit - the disappearing dot - rounding up it should be 50.
    SWG
    Well water
    Full sun
    May 2014
    Franklin, NC
    9,179
    Re: CYA dropped?
    Quote Originally Posted by Lrinaldo99 View Post
    OK, now,we are on the same page. There is no 48, round to 50.
    Have we replaced a lot of water? Heavy rains? Pool party?
    Other than very minute amounts, the only way CYA goes down is with water leaving the pool.
    Support the site
    Jun 2016
    Ithaca, New York
    50
    Re: CYA dropped?
    Ok. We have a slow leak. Yesterday I turned on the hose to add water and forgot about it, so I added more than I intended. Perhaps that is the culprit? If that is the case then should I still use the stabilizer?
    SWG
    Well water
    Full sun
