Thread: CYA Reading
    May 2015
    New Milford, New Jersey
    68
    CYA Reading
    Hi Everyone,
    So things have been going fine all season, I test FC & PH regularly, only use liquid chlorine (I have done great with the Wal-Mart pool essential), test TA & CH periodically and everything been great. I decided to test CYA this weekend and I am getting no reading, meaning its below 20????? My chlorine does not appear to be getting used up abnormally fast, what is going on? What should I do? As always, thank you in advance for your help!
    Adam
    17x34 and ranges in depth from 3 ft to 6 ft.; I think 20-22 thousand Gallons
    IG -Vinyl with Waterfall
    Hayward Super Pump 1.5 HP
    Pentair DE 60 Filter
    Hayward H300 Heater; Taylor K-2006 Complete
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: CYA Reading
    Adam,
    I guess my first question would be what are your targets for FC? You are fairly well north, so not the blazing sun our friends in Florida, Texas and Arizona face so maybe your daily loss to UV is not bad.
    Support the site
    May 2015
    68
    Re: CYA Reading
    At the beginning of season I got CYA to around 50, so target had been 6; do I need to add more stabilizer? Is there any other explanation?
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,153
    Re: CYA Reading
    You can try the R-7065 CYA (50 ppm) standard solution to rule out any problems with your R-0013. It is basically pool water with a CYA of around 50 ppm.
    Have you had a lot of rain? Splash out from kiddos in the pool?
    May 2015
    68
    Re: CYA Reading
    What is the R-7065 because I do want to rule out a problem with R-0013???
    Not a lot of rain but yes a lot of splash out, I have to add water almost weekly, did that do it?
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,153
    Re: CYA Reading
    Here is link to 2 ounce size of R-7065 TFTestkits.net
    Use it like pool water mix with R-0013, and you should get a reading of 50 ppm (give or take 5 ppm
