Results 1 to 7 of 7
Thread: GFCI Switches Keep Blowing
    Jun 2015
    Fenton, MO
    7
    Iím having a problem with my pool light. Every time the timer tries to turn on the light, the GFCI switch blows. I reset the GFCI switch, reset the timer and manually turned on the pool light and it would work again. It would go off at the appointed time but then not come on the next day as the switch was blown by then. A week or so later, the pump started doing the exact same thing and blew the switch - I did the same resetting steps for a few days and the issue continues. I am now bypassing the timers and re-starting GFCI each time to get the equipment to come on. It now goes off when it eventually trips the switch, sometimes a few times a day. The salt water chlorinator is now tripping it's GFCI switch as well. This switch is not on a timer at all, if that makes a difference. Any ideas on what is going on?
    15,000 gal 14x28 IG vinyl liner pool - Hyrda Pools, Hayward sand filter, Hayward 1.5 Pro pump, Aquarite 1500 salt water generator. Install June 2015.
    Apr 2013
    Sacramento, CA
    2,769
    Re: GFCI Switches Keep Blowing
    Are these GFCI breakers or outlets? Are they the same GFCI?
    Anyway on the facts you provide I would get a good electrician look at it. Since this is less than a year old I old call the pool builder and have him send out the electrician who did the original work.
    May 2015
    kingston springs, tn
    102
    Yes are you talking about GFCI circuit breakers in your electrical panel? Either way in my opinion especially if you are having more than one problem with breakers or plugs tripping you have a grounding issue, short circuit, or the neutral is tied directly into the ground. Water and electricity are a DEADLY mix extra especially a swimming pool. You need a qualified / licensed electrician NOW. Do not swim in the pool until you get it repaired.
    18x36 IG vinyl 18,000 gal, Hayward super pump 1hp - 1.5" pipe, Pentair Triton TR-60 sand, Pentair Itellichlor IC-40 SWG, Pentair Intellibrite 5G 12v color LED light, Polaris 280 cleaner, Hayward Booster pump, Intermatic Power / Timers.
    Jun 2015
    Fenton, MO
    7
    Quote Originally Posted by gwegan View Post
    Yes, it is the GFCI breakers inside the panel. Each switch is labeled light, pump & salt water generator.
    Jun 2015
    Fenton, MO
    7
    Yes, the GFCI breakers inside the electrical panel are the ones tripping. I have a separate panel that has the main electricity shut off. If I were to shut this one down, would we be safe to swim until I can get an electrician out there?
    May 2015
    102
    I would still wait and not swim until I got it checked out. You could have a short on your ground coming from another power source.
    Apr 2013
    Sacramento, CA
    2,769
    An energized ground wire would generally not be tripping a GFCI.
    Power off at the breakers should be fine to swim.
    Call an electrician.
