Results 1 to 17 of 17
Thread: SWG FC Generation Level @100% / Super Chlorinating - "The Norm"
    hoskim's Avatar
    May 2016
    Berkeley Heights, NJ
    83
    What is the "normal / typical" level of FC being generated by a salt cell (I have Hayward T-CELL-9) at 100% / Super Chlorinating. Although I have gone through SLAM twice, I continue to experience FC loss (even with CYA of 70-80).
    While recognizing my test was not exactly accurate / scientific, I placed (with my thumb to cover) a sample tube and syringe in front of my return to capture the FC level (tube = 2.0, syringe = 2.5). All indicators are within range and my salt level is 3400 ppm. My cell is exactly three years old and being used 3-4 months a year.
    Is this normal?
    Thanks!
    25,000 Gal, in-ground w/ vinyl liner
    Hayward SP2303VSP (1.5 HP) / DE filter (4820)
    Aqua Rite SWG / T-CELL-9 (v1.5)
    Polaris 380, PB4-60 Booster Pump (post-2012) / Aqua Heat Pump (S95)
    TF-100 Test Kit with Speedstir
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: SWG FC Generation Level @100% / Super Chlorinating - "The Norm"
    How many hours a day are you running your swg?
    We recommend that your swg be 2 to 3 times the size of your pool. Your cell is a little small and you would need to increase the hours your pump runs. A larger cell can provide enough chlorine with much less pump run time.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    hoskim's Avatar
    May 2016
    83
    Oh..yeah...for got to mention. At least 10 hours...10AM to 8PM but I have run more (like 24 hours) in the past frequently. The previous owner indicated he ran 9 - 5 with no issues so I am wondering whether my cell is "bad." Also I doubt our pool is 25K as the previous owner claimed and closer to 20,000 - I have noticed this when I was adding salt and CYA (that the calculation based on 25K was a bit too much). May be I should consider buying a T-CELL-15 when this one goes....Thanks!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    The most common cause for an SWG "not keeping up" is some algae in the water consuming FC. It is easy enough to test for it, shut off the SWG and do an Overnight Chlorine Loss Test to see if there is something brewing in the water. If it doesn't pass then give the pool a quick SLAM
    hoskim's Avatar
    May 2016
    83
    Thanks for your advice and i was afraid of going through SLAM again (which actually worked well in the past). But difficult to think that SWG "only" generates 2.5 FC at Super Chlorinating mode while Hayward indicates "if you want to shock the pool......"
    Jul 2014
    Hope Mills, NC
    567
    The T-9 cell is way undersized for your 25,000 gallon pool. That may be your problem.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    hoskim's Avatar
    May 2016
    83
    Got it and so much for mfg's capacity recommendation..i guess i need a t cell 15 then...
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    The manufacturers recommendations are based on running 24/7 at 100%.
    Karen
    hoskim's Avatar
    May 2016
    83
    Understood and that's a great insight....(while recognizing my ignorance being a first year pool owner, nevertheless), I feel like a car manufacturer claiming 100 MPG with a fine print...."only if you drive downhill"
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I like your analogy! I may have to steal it.
    Karen
    hoskim's Avatar
    May 2016
    83
    Hahaha..thanks...
    38,472
    Well, no one ever really answered your question with numbers:
    A T-9 running 24 hours at 100% will generate 0.7 pounds of chlorine gas.
    In a 25k pool, that would be 3.4ppm of FC.
    A normal clear pool loses 2-4ppm of FC every day. So, I would expect for you to have to run your SWG at 100% for close to 24 hours a day to maintain adequate FC.
    FYI, the T-15 has double the output (1.4 pounds per day).
    hoskim's Avatar
    May 2016
    83
    Thanks!! Where did u get these numbers? I tried to find the figures but just couldnt..hence the posting....thanks again!!
    38,472
    The 0.7 pounds is published information. HERE is one source.
    I then used the "Effects of adding chemicals" section of PoolMath to calculate the FC ppm addition.
    hoskim's Avatar
    May 2016
    83
    Thanks again! Great info...I am opening my wallet now...reluctantly.....
    May 2015
    Land O Lakes, FL
    527
    JBlizzle has it right.
    I am calculating 21.5 hours required to run with a daily FC loss of 3 PPM @ 100% output. If you have a day with a PPM loss of 4 or more PPM, the SWG cannot generate enough Chlorine. At 4 PPM loss, 28.7 hours would be required.
    If I were you, for now, I would do one of 2 things, both require daily addition of Bleach.
    1. Run the pump 15 hours a day to replace 2 PPM each day and test daily and add bleach as required. Some days, it might not be needed.
    or
    2. Run the pump as little as needed, lets say 6 hours and test daily and add bleach each day.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    hoskim's Avatar
    May 2016
    83
    This is really helpful and thanks!!
