Thread: Old & New Extendable Handles for vacuum, skimmer & brush spin & slide vs locking
    May 2015
    Denver, NC
    6
    I have two handles I use for the skimmer, brush & vacuum.
    One is an old aluminum set of poles with a screw tightener, the other is a new one with a plastic flip lock.
    Both of these spin and slide when I am vacuuming. It is very annoying and takes more time.
    I am ready to get some JB Weld out... Has anyone solved this?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Old & New Extendable Handles for vacuum, skimmer & brush spin & slide vs locking
    How about a drill and a pin as a back up to the existing setting, just below the tightner, maybe two settings on the inner pipe.
    Set it at the short level, drill through both pipes, then an extended setting drill through the existing hole on outer pipe through the inner pipe. You could use replacement pin from the pool skimmer pin or a metal one from a tow hitch or similar.
    May 2015
    Denver, NC
    6
    That is an awesome idea! simple. elegant. sometimes we go way down the rat hold solving a problem.
    Thankful for the community... Head out of hole now. Holes to be in handle next.
    14,000 gallon fiberglass kidney shape pool.
    Old 1hp Whisperflo WFE-4.
    Sand filter & fountains I turn on once for every guest to see a few times a year.
    Illupo's Avatar
    Jul 2016
    Scottsdale
    37
    Excellent idea...thanks! I too have a pole which is in perfect shape EXCEPT some kind of offset plastic piece inside that if you twist a certain way, it temporarily locks the two halves together. (which stays together halfway through my vacuum job) It is annoying to say the least. You just saved me dough as I was about to buy a whole new handle!
    Inground 1800 gallon gunite spa/pool, installed mid 1980s.
    Pentair Clean and Clear Plus 4 cartridge filter Model CCP 240
    Pac Fab Challenger (High head, High flow) 1 1/2 HP pump
    One Jandy valve controlling automatic chlorinator
    26venus's Avatar
    Jul 2013
    Shenandoah Valley, VA
    48
    You could also use these in the holes...1 set of holes on the internal tube (install clip) and as many adjustments you'd like on the outer tube.
    Amazon.com : Pool Butterfly Clip for Pole Attachments - Package of 5 : Swimming Pool Maintenance Kits : Patio, Lawn Garden
    16 x 36 IG Vinyl, 20,000 gal, chlorine, built 2001
    Hayward 3/4 HP Super Pump
    Hayward Pro Series sand filter S210T
    All in with TFP , testing with tf-100
