Results 1 to 10 of 10
Thread: My take on the PVC poolside table
    Jul 2016
    Boaz, KY
    17
    Borrowing from the designs posted in this thread, PVC Tray Holder For Intex Metal Frame Pool (I Should Patent This!)!) This is the variation that I ended up with. This was an easy, cheap diy pool project that anyone could do in an hour or so. My version has a non removeable tray, that is simply an old storage tote lid, cut to fit, and zip tied to the PVC table frame. With it being zip tied, it won't hold water, and, the PVC frame provides a raised edge to keep items in place.
    David
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Re: My take on the PVC poolside table
    Nice job!
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    KazzyK810's Avatar
    Jul 2016
    Davison, Michigan
    75
    Sweet! Thanks for sharing! I was playing with PVC last week and have some leftovers. I might give something like this a go!
    Karan - 18 ft round x 48" high - Intex ultra-frame AGP, Intex 3/4 hp pump with 14" sand filter (SF70110), Hayward 900 Wanda the Whale cleaner, Intex LED water fountain.
    18ft Round Intex Ultra Frame in The Mitten
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    340
    here is the one that i did. so very simple after a trip to home depot.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Nice! I see a project for me! What size PVC pipe did you use?
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Jul 2016
    Boaz, KY
    17
    Quote Originally Posted by Glock View Post
    I used 1/2 inch pipe and fittings. The 45 degree elbows I used, were 3/4 inch with bushings, simply because my local Lowes was out of the 1/2 inch, and, I didn't feel like wasting gas going some where else to get them, lol. The original design thread I linked to has a good parts list in it. Also, when I cut the two large T fittings that go on the pool frame, I only removed a strip approximately 3/4 inch wide. This allows the T's to snap over the pool frame, and still have a good hold that will not slip off unless intentionally removed.
    David
    Cypress, Tx.
    154
    Here is the tray I made a couple of weekends ago
    Intex 18ft dia. Ultraframe, 6500 gal. above ground Intex pool with Hayward C550 cartridge type filter and Intex Krystal Clear Ozone and saltwater system model ZS8110, Taylor K-2006 test Kit, Pool filter supplemented with Duda Diesel 1 micron filter bag
    Located in Cypress, Tx.
    Jul 2016
    Noblesville, IN
    30
    Gtty - I love the cabana for your pump and filter!
    Pete and Family
    Graduated from baby wading pool to Quick Set Intex 10 ft to Intex steel frame 12 ft over the last 5+ years
    Just purchased BestWay 22 ft x 52 in on clearance - will graduate to it next spring!
    chayne's Avatar
    May 2016
    340
    I really like that cabana also. Give us a close up of that if you don't mind
    Charles
    Coleman 16'x48"
    Cypress, Tx.
    154
    Quote Originally Posted by chayne View Post
    Sent from my SM-G925V using Tapatalk
    thanks Y'all
    I'll try to take some photos this evening. My sewing really has a lot to be desired and it didn't turn out as professional as I would have liked, but it does the trick and keeps the rain and splashed saltwater off my pump motor, which is what killed the previous motor.
