Thread: Measuring CC
    Jul 2016
    Carlsbad, CA
    29
    Measuring CC
    My DPD test kit can measure free chlorine (FC) and total chlorine (TC). The difference is supposed to be combined chlorine (CC). It is hard to tell exactly what the difference is between the FC and TC readings. Is there a more accurate way to measure CC directly?
    16,000 gallon outdoor in-ground 16'x32' plaster pool (built 2002); Pentair Intelliflo VF pump; Jandy Cartridge filter;Rainbow in-line chlorinator (used only when I am away); Hayward 2 wheel suction-side pool cleaner; LARS gas heater, Taylor K-2006 FAS-DPD test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Measuring CC
    Welcome to TFP!
    Yes, with an FAS/DPD chlorine test you can more accurately measure FC UP to 50 ppm and more accurately measure CC too. Get one at TFTestkits.net If you don't already have a good test kit get a TF-100, it includes the FAS/DPD test.
    Pool School - Test Kits Compared
    Jul 2016
    Carlsbad, CA
    29
    Re: Measuring CC
    Thanks. I just ordered one on line
