Thread: Helping a friend convert to tfp
    Friend has a in ground pool vinyl lined pool....water is very cloudy white...pool store has been telling them to add this and that and to stop back in a couple days and go from there....went there this a.m. with my k2006 and....
    Fc=2.5
    Cc=0
    Ph=8.0 was almost off chart
    Ta=130
    Cya=0
    Did the cya test 2 times because i expected it to be high...they have been useing granular clorine out of a 5gal bucket this year and the bucket is about empty....she leaves it sitting out at the pool in the sun....will this degrade the clorine in the bucket ? And why is there not any cya.... i thought with useing the granular that there wouldve been some cya in there...or has this been totaly been robed of everything from being stored outside in the sun....
    There stocked on liquid clorine as of now and throwing away the bucket....going back later today to check the #s again
    Cya being added right now and ph being adjusted with acid.
    24' x 52" VINYL AG 15,200 GAL.
    HAYWARD POWER FLOW LX 1.5 HP
    HAYWARD SAND FILTER
    Taylor K-2006
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Helping a friend convert to tfp
    That bucket was probably cal-hypo. That is stabilized with calcium not CYA. you might want to check their ch level.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    May 2016
    Phoenix AZ
    128
    Yes, that sounds like it might be very high calcium level.
    50,000 gallon plaster in-ground salt pool with two 60 sq ft DE filters, two Intellichlor IC60 SWGs, two Intelliflo VS pumps, two Whisperflo pumps, two Pentair 400K BTU NG heaters, PCC2000 in-floor cleaning system...two everything.
    Im going back to there house in a couple hours. ...looks like if the ch is off the chart they need to replace some of the water according to pool math...so i should have a reading of 350 or lower ?
    HAYWARD SAND FILTER
    Taylor K-2006
    Test results this a.m.
    Fc= 2.5 added to bring up to 5 as per pool math
    Cc= -.5
    Ph= 7.4 added mr to lower to 7.2
    Ta=110
    Ch=475
    Cya= did not test...added cya yesterday to get to 30ppm
    Was unable to see the bottom of shallow end yesterday. ..this a.m. was almost able to see bottom of deep end.
    I could see alot of debris on the steps...told pool owner to vacuum asap and ill be back tonight to retest
    HAYWARD SAND FILTER
    Taylor K-2006
