Results 1 to 11 of 11
Thread: Hayward Power-Flo just buzzing
    Jul 2016
    pasadena
    12
    Greetings all, long time reader first time poster.
    So last week i hard plumbed my intex pool to use a hand me down Hayward Power -Flo pump and DE filter. Hooked it all up and fired it up yesterday and she ran like a dream for 6 hours. This morning i went out to turn the pump on and now it just hums but no turning. I found that i if i leave it plugged in and let it hum for about 60 seconds it trips the breaker. I also saw a tad bit of smoke from the pump housing.
    The motor does not have a capacitor, and i wont try to name the parts it has because i have no idea.
    What would cause this? Thanks in advance!
    Btw impeller spins but no flat head on the back to try to bump start it
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Hayward Power-Flo just buzzing
    Check the centrifugal switch contacts (copper Y) to make sure they are not corroded.
    Mark
    Jul 2016
    pasadena
    12
    Is that the plastic V at the bottom or the black circle piece at the top. Also should the spring loaded flap that the plastic V is up against be closed or open before start?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Yes the white/yellow plastic with the copper. The spring flap is the governor and when the motor is stopped, it pushes up on the contacts so the starter winding is engaged. If they are corroded, the starter winding may not be getting power. However, if the contacts are good, then the winding itself may be bad.
    Mark
    Jul 2016
    pasadena
    12
    Ok I'm out of town for a couple days so the intex pump is running for now, and ill check that out and update thanks
    Jul 2016
    pasadena
    12
    So took it apart and cleaned all the contacts. Windings and shaft still turn smoothly. The metal flap is pushing and engaging the centrifugal switch when off, but nothing is separating those contacts when power is put to the pump. Aslo i tried pushing that flap down (separating the centrifugal contacts) while someone else plugged it in,and nothing. Any more suggestions? Thanks
    mas985's Avatar
    Pleasanton, CA
    11,737
    Unfortunately, I think the next step is a new motor.
    Mark
    Jul 2016
    pasadena
    12
    Was afraid of that, but also kinda figured. I just hate not knowing why it wont turn over
    mas985's Avatar
    Pleasanton, CA
    11,737
    You can try turning the governor with power on using a stick. Be careful though. If it starts rotating, it is the starter winding.
    Mark
    Jul 2016
    pasadena
    12
    Bumped it and it fired right up, what now?
    I'd rather not bump start this thing every day lol
    mas985's Avatar
    Pleasanton, CA
    11,737
    Bad starter winding. But check all the wires that connect to the terminal block and centrifugal switch to make sure none are loose.
    If still no good, then I would say you need a new motor.
    Mark
