Thread: ic40 chlorine output changing??
    Feb 2013
    Nashville, TN
    49
    We have noticed in the past week that our pool's chlorine level was low, so we upped the percentage on our ic40 SWCG. Next time we looked at the ic40, the chlorine output had kicked back to a lower percentage without us having touched it. This has happened several times this week. Any idea what is causing this. It is 3years old.
    Sharkline Matrix 28', Pentair SD80 sand filter, Pentair Optiflo 1hp/2spd pump, Intellichlor ic40 (installed 7/2013)
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Re: ic40 chlorine output changing??
    How are you upping the %? If you are hitting the 100% or Boost function (and it works like mine) it does revert back to the previous setting in 24 hours.
