Thread: Repeated Spider Gasket Failure in Multiport Valve
    May 2014
    Rogers, AR
    8
    Hi all,
    Over the past 2 years I have had issues with Spider Gasket failure (5 times) - Pentair Multiport side mount 2" Sand.
    I occurs over time after backwash, waste or rinse operations...
    Before asking, YES to all below:
    Turn off the pump before rotating valve
    Always rotate in same direction
    AND - absolutely depress handle fully/
    The failure seems to be one (ore more) spoke(s) where the large diverter opening will allow the water to travel past (over) an exposed spoke. (Personally, I see it as a design flaw with the valve.)
    When I am finished backwashing, pumping to waste, etc... eventually the gasket is pulled up and then allows water to pass to backwash when in filter (run) position.
    Note - I have tried NUMEROUS adhesive techniques... Including the Blue ATV (manufacturer recommended) and vinyl patch repair adhesive (recommended by LPS)... Always completely clean before applying. Note also - I have tried magic lube on diverter plate to prevent sticking. Still ultimately fails.
    I am wondering if the following may be a factor in the failure.
    2 years ago I had a gas heater installed. There is a bit of science around lengths of pipe vs. #'s of elbows, etc. My CLEAN sand filter pressure moved from a 10 lbs of pressure to 15 lbs. I was told not abnormal. I am concerned that it is possible that there may be a GREAT DEAL of water turbulence at the point of entry to the Multiport Valve.... Beyond that, I am out of possible causes.... Any ideas appreciated!
    Northwest Arkansas
    15K Viking Fiberglass - Salt Water - Pentair Intellichlor IC40 SWG
    1 hp Whisper Flow Pump w/Triton II TR60 Sand Filter
    Pentair MasterTemp 125K BTU Natural Gas Heater
    30,415
    Re: Repeated Spider Gasket Failure in Multiport Valve
    Failed five times and you are doing everything correct? It's time to change the multiport valve.
    May 2014
    Rogers, AR
    8
    Thanks ... That is where I was landing. I am third owner of the pool and this equipment is right at 9 years old.
    Northwest Arkansas
    Jan 2012
    340
    Do as duraleigh says and replace.
    Look at swapping for a push/pull valve. A few less options, but much easier to maintain.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
