Thread: going from green to white oily looking substance on surface
    Jul 2016
    Forest city nc
    5
    Thank you for this website. I was able to take the pool from very green at opening in mid May to totally clear today using the forum and resources on this website. This is the first year we have struggled to get to clear water. We got to cloudy after opening then upgraded the pump and added thee ozone treatment. Then I used the wrong algaecide, then I used the wrong bleach - the bottle said regular but it was not regular. We scooped foam 3-4x per day and cleaned the filter daily. We dumped about 6in. of water per day. The cell will generate at only 5% and we have a new cell on the way so we have been adding bleach daily. The entire pool is in full sun about 2 hours per day otherwise only sections of the pool are in full sun. Here is where we are and I'm stuck. I'm still getting this white oily looking substance on the top of the pool.
    The white is not suntan oil or anything like that since no one has been in the pool for over 2 weeks because of the foam.
    This morning the levels were FC 2, CC 4, FC 6, CYA 45 Alk 80 PH 7.5 salt level 3.3 - yes I have purchased the TF 100 kit and now have the title of mad scientist. Not sure if I am doing this correctly but the numbers look pretty good I guess.
    The water is very clear. If the pump runs on 3 there is not any foam or white oily looking substance. If we put the pump to 4 - maximum, the white comes out and only a very little almost nothing for foam.
    1. is it safe to swim if we keep the pump on lower levels (I can't bring myself to get into a pool that has a white film)
    2. What is the final step on this to get us to a routine
    3. any suggestions when we go on vacation? I have someone checking on things daily.
    Inground fiberglass 12,000 gallons. Jandy 2.7 variable speed pump. Aqua pure Aqua link salt chlorinator. Eclipse 20 ozone pool has heater.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: going from green to white oily looking substance on surface
    Welcome to TFP!
    Remember, chlorine is your friend. You need to use the correct bleach (don't feel bad, many have had this problem), no more algecide and SLAM the pool.
    As to vacation, your CYA can handle some pucks if you don't have the SWG back running by then or your house/pool,sitter could add bleach each day. Your choice.
    Resist the temptation to add floculants or clarifiers as this can make your problems worse.
    Support the site
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Your FC (2ppm) per your results is too low for your CYA. SLAM and then maintain per your CYA.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Jul 2016
    Forest city nc
    5
    OK Thank you.
    We subscribe to the 3 Bs plain bleach, borax and baking soda nothing else this has been an ordeal.
    Are the levels too dangerous to swim? Then SLAM later. I have not been in the pool since we opened it. Understand if you don't want to answer this question.
    If not, we will SLAM and hopefully swim when it is ready
    THANK YOU for this site.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Camr View Post
    Im confused.... You say you follow BBB, nothing else but you used algecide and have added an ozone system. Both of these are unnecessary in a properly maintained outdoor pool.
    Cloudy water after an algae incident = SLAM.
    Support the site
    Jul 2016
    Forest city nc
    5
    sorry for confusion I now use the three b's Was not educated when I used the algaecide then wrong bleach.
    Proceeding to SLAM should be good to go after and move to maintain
    Thanks again
