Thread: Test results new pool owner
    Jul 2016
    Central pa
    6
    Just received the tf-100 test kit and here are the results (new pool, just filled and chemicals added three weeks ago):
    pH 7.5
    FC 3
    CC .5
    TC 3.5
    CH 125
    TA 90
    CYA 40-50 (dot disappeared between these two numbers)
    I guess the hardness is alittle low (but that shouldnt matter since the pool is vinyl liner??) Also with the low CH this is trowing off the SI as I am getting around -0.45 (but once again should this matter since there is a vinyl liner?)
    Water is crystal clear
    Located in Northcentral PA
    Pool receives direct sunlight from about 8:00am - 6:00 p.m.
    current water temp 82
    Any other input or suggestions would be greatly appreciated. I have been doing my reading on this site for the last week and learning alot. I will be donating some $ here the near future (best site on the web).
    16x32 IG SWG 18,000 gallons
    Vinyl Liner
    Pentair intelliflo variable speed 3HP
    Pentair Water IntelliChlor
    Pentair Sand Dollar sand filter SD-80
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Test results new pool owner
    Welcome to TFP
    Using bleach or liquid chlorine bring your Free Chlorine to 6 (CYA 50) and stay above 4 FC...
    ******** just saw, do you have a Salt Water Generator*****
    If so, bring your FC to 6 for now and using granular CYA in a sock bring your CYA to 70, it will help your SWG keep the FC up..
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Welcome to TFP!
    You are correct that your CH and CSI is fine for a vinyl pool.
    Jul 2016
    Central pa
    6
    Thank you for the advise. Greatly appreciated
