Thread: Unable to control a Jandy LXI heater
    Jun 2015
    Toronto Canada
    11
    1.My Jandy LXI Heater is working fine in manual mode but I cannot control it with my Jandy RS controller.
    Yesterday I installed a new CPU and bezel control board ( I am planning on a multi speed pump and needed a newer revision of firmware ) and I hoped it would get rid of the problem but still there
    Any ideas
    I understand that you can control this heater with an RS485 cable - would that make the problem go away
    2. I am planning on installing an IQ20 phone remote control and a jandy multispeed pump 2.1 hp and this heater via RS485
    what is the most cost effective way of connecting them to the new mother board/bezel
    thanks for your help
    18x36 free form gunnite about 30000 gallons
    spillover spa, waterfall
    separate pool spa waterfall and polaris pumps
    Jun 2015
    Toronto Canada
    11
    Re: Unable to control a Jandy LXI heater
    oops - I forgot to ask - re connecting more devices there are 2 red connectors - with 4 pins does it make any difference which one I use or are they both the same and where does one buy the actual connector that slides onto the 4 pins
    Quote Originally Posted by Franklin View Post
    Any ideas
    Apr 2015
    tucson, arizona
    1,120
    https://www.google.com/search?q=jand...utf-8&oe=utf-8 You need rev. N or higher to use the RS485 cable. One can go to any controller the other to heater. If you need more they have a multiplex board with four connectors
