Thread: Questions about going on vacation
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    We are leaving Friday for vacation and will be gone 8 days. We have someone coming daily to turn the pump off in the day and on at night. With the cover off we have been adding 10 oz of 10% bleach (per PoolMath) each night. With the cover on, how much should we have her add and how often?
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Re: Questions about going on vacation
    The only way to know that is to do it for a while. It will vary from pool to pool. I would also raise FC up to shock level for your CYA, FC/CYA Chart, as an extra buffer.
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Thanks
    VinDeeLoo
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    With the cover, I might recommend going to shock and using tabs for the 8 days, depending on your current CYA level.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    It is around 30 right now.
    VinDeeLoo
