Thread: Air relief valve issue?
    Jun 2016
    New Jersey
    3
    I have a pre 1999 nautilus fns 48 de filter. Recently there has been a consistent gurgling noise coming from the top of the filter housing which seeems to be coming from the air relief pressure valve system. No water is escaping from it and I sprayed shaving foam around area but didnít see anything.Pressure reading is at 20 lbs which is normal but seems to be jumpoing around a little bit. Everything else in filter system seems to be fine no air in strainer housing,good prime and minimal air bubbles from return jets. Any thoughts on cause and how to correct. Thanks
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Air relief valve issue?
    Welcome to TFP
    when you purge the system, does air come out and then water right after.. then the sound stops? it may be getting some air in there when the pump turns on and staying in the top of the filter..
    Jun 2016
    New Jersey
    3
    Quote Originally Posted by cowboycasey View Post
    Welcome to TFP
    I tried that and it did not stop noise.
