Thread: Tf100 test kit R-7065
    Jun 2016
    Manteo north carolina
    50
    What is the r-7065 for? For testing the cya according to the instructions that came inside of kit doesn't say to use it, but when I look on line at instructions it says use it.
    Above ground intex 24x 52 Swg with sand filter pump. Well water. New started the end of May. 11,600 gallons. Test kit TF100
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,147
    Re: Tf100 test kit R-7065
    R-7065 is a reagent used to test your R-0013 and/or your CYA testing method. You don't need to use it when performing your every day or every week tests. It is like having the answer sheet to a test. I use it only occasionally when I go to test my CYA and it shows I have close to no CYA in my pool. Then. I am like "Hey, that's not right". Then, I pull out the R-7065, mix it with R-0013 and it shows a reading of around 50 ppm CYA. So, now I know I need to put some CYA in my pool. You don't have to use it very often. I do it at the beginning of pool season to test my R-0013. It also helps you test your testing method.
