Results 1 to 15 of 15
Thread: numbers day after adding borates
    May 2009
    Florida
    45
    Added borates yesterday with the borax/acid method.
    Here's the latest,
    FC 3
    TC 2
    PH 8
    TA 140
    CH 225
    Will test the borates tomorrow.
    Should I correct the PH and TA now or wait another day to see if they come down?
    14,275 gallon inground ~ Pentair Cartridge cc200 ~ Pebbletec Tahoe Blue ~ SWG Intellichlor IC40 ~ Pentair Whisper 2hp ~ Taylor FAS-DPD Test Kit
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: numbers day after addding borates
    your fc and tc are off. did you reduce the ta before you added borates? I believe JasonLion has mentioned it is much harder to lower TA after borates.
    May 2009
    Florida
    45
    I did lower the ta and was surprised to see it so high.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    the 20 mule team borax I used raised my TA by 20 (from 80 to 100). have you read waterbear's post about halfway down the page in this thread?
    so-you-want-to-add-borates-to-your-pool-why-and-how-t4921-60.html
    he talks a bit more about the ph.
    I would go ahead and lower the PH to around 7.5.
    May 2009
    Florida
    45
    thanks,
    what's up with the FC and TC is that a false low on the TC?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by kenny
    thanks,
    Repeat the test.... testing error? TC cannot be less than FC. Not possible.
    May 2009
    Florida
    45
    error on my part, yup that seems about right.
    thanks.
    Re: numbers day after adding borates
    Are you getting the TC reading from the OTO test (drops turn the sample various shades of yellow)? Using the OTO test it is very difficult to distinguish the shades of yellow for TC levels from 2 to about 8, they all look very similar and don't really match the color samples for 3 and 5. It takes a lot of practice, and comparisons back to the FAS-DPD test, to be able to read OTO values above 2.
    May 2009
    Florida
    45
    I'm using the Taylor Test kit from Leslie's.
    How long should I wait to retest after adding acid?
    May 2009
    Florida
    45
    Getting better.....
    FC 5
    TC 5
    PH 7.2 (aerating)
    TA 110
    CH 175 (pool company told me not to add CH for 90 days after construction)??
    CYA 50
    When was your PebbleTec applied?
    May 2009
    Florida
    45
    It's been 30 days.
    You don't want to lower your TA too far before you raise the CH level. I would normally add CH after four to six weeks. But you don't want to do anything that would jeopardize the warranty.
    May 2009
    Florida
    45
    Thanks, that's what I was thinking too......keeping the TA high with the low CH. Once I can start adding CH, what would be a good TA and CH level to maintain?
    The pentair manual for the SWG recommends a TA at the high end of 120 but that seems opposite of the recommended levels on this site.
