Thread: How important is CH?
    emaschke84's Avatar
    Mar 2016
    Blackwood/NJ
    35
    My latest results
    Chlorine-5.5
    TC-5.5
    PH-7.8
    CH-50
    TA 110
    CYA-60-70
    Salt- 3400
    I have consistently run at 50 CH from the start. The calculator says I should be higher (150). My water is always clear, and everything seems fine. I fine tune chlorine and PH weekly. Should I add 10 lbs of calcium chloride, or leave well enough alone? What else gets affected by adding it?
    18'x35' 11k IG Vinyl 3.5'-5.5' with 9' sun deck and xtreme slide
    Pentair DE FNS-36, Pentair Superflow 1.5 hp, Simple Blue SWG 25000,
    Pentair Intellibrite 5G LED, Aquabot JR Z1, TF-100, K-1766
    Jul 2015
    Central Valley CA
    1,107
    Re: How important is CH?
    It will climb over time with evaporation/refill but largely not a concern for vinyl, so I wold leave it alone. If you had plaster would suggest raising it.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    emaschke84's Avatar
    Mar 2016
    Blackwood/NJ
    35
    Quote Originally Posted by atttech-2 View Post
    Thanks
